11-25-2002, 02:00 | #1 (permalink) |
No Life Poster Join Date: Mar 2002 Location: tunis,tunisia Age: 48
Member: 10396 Status: Offline Thanks Meter: 32 | clean CCONT surface??? how to clean suface for ccont plz i used many liquid for cleaned and i hotest this surface for remove cole but no sucess. any idea plz. |
11-25-2002, 06:21 | #3 (permalink) |
Freak Poster Join Date: May 2002 Location: Perth, Western Australia Age: 45
Member: 11937 Status: Offline Thanks Meter: 1 | I have found the best way is to use liquid flux. i have SMD flux in a spray bottle, it works great. Apply the liquid flux onto the CCONT, and then use desoldering braid, it will sizzle, and spit, but it will remove all solder. Then use a flux remover to clean all residue off, and its beutifully clean!!!! |
11-26-2002, 05:37 | #8 (permalink) |
No Life Poster Join Date: May 2001 Location: Bulgaria Age: 56
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks Meter: 1,034 | You must use hot (non so high temperatute) air and blade or arrow, not more. And keep patience . This way yesterday i was resold MAD2 on one N6210 with paralel COBBA test failed for not more that a hour... and phone is OK now. Debelia Mark, BG |
12-02-2002, 13:59 | #9 (permalink) |
Junior Member Join Date: May 2002 Location: manila
Member: 11508 Status: Offline Thanks Meter: 0 | Hello! I use 10% ammonia solution and ultra sonic cleaning unit. I put pcb in cleaning unit and put enough liquid to cover it and plug it. I let it run 10 minutes. This process makes all impurities removed from any surface. Rinse with purified (not mineral) water and flow-dry board. Please use medium heat but very low air. BGA chip will bubble underneath and push out flux/impurities. Let cool. clean surface with contact cleaner (use brush if needed but very gently and only when cool) and reflow to dry. Board now is shiny clean. |
Spin 'N' Clean 2-In-1 Cleaning Kit (DGUN-116) | IPMART | ipmart WebShop | 0 | 06-17-2009 13:10 |
Visible Dust Chamber Clean Liquid, Camera Cleaning Kit, 1 oz. | IPMART | ipmart WebShop | 0 | 10-21-2008 12:20 |
Deep beneath the surface... | --=ReviveR=-- | S-Gold Based Phones | 14 | 06-30-2004 11:21 |
