Old 02-01-2009, 02:40   #46 (permalink)
Member: 751249
Sonork: 151515999
Thanks Meter: 18
check shoting in nokia phones in one exe no link found on url please upload again. thanks.
but its very good job i salute u.
another link nere....
The Following 6 Users Say Thank You to p0er08 For This Useful Post:
Old 02-03-2009, 07:43   #47 (permalink)
neeraj1st's Avatar
Member: 271008
Thanks Meter: 280
i have a n 70 its battery backup is only 16 hrs standby wats the problem is there any shorting
The Following 5 Users Say Thank You to neeraj1st For This Useful Post:
Old 02-10-2009, 09:25   #48 (permalink)
Member: 285779
Thanks Meter: 49
hello sir . i'm currently working on 6120 with problem when i put on power supply it raise to 20ma . the phone working properly just with quick low batt . any guide on this problem ?
thx in advance
The Following 3 Users Say Thank You to amei8141 For This Useful Post:
Old 02-12-2009, 03:49   #49 (permalink)
watari31's Avatar
Member: 141262
Thanks Meter: 348
thx in advance
board is shorted by 20ma try checked the for possible water corrusion
or check the post by digitized for 6120 shorting!!
The Following 3 Users Say Thank You to watari31 For This Useful Post:
Old 02-15-2009, 08:03   #50 (permalink)
Rizwan ch08's Avatar
Member: 637860
Sonork: 100.1605309
Thanks Meter: 996
good job sir ...........................
The Following 2 Users Say Thank You to Rizwan ch08 For This Useful Post:
Old 02-17-2009, 02:24   #51 (permalink)
Member: 74704
The N96 switch on black hold to settle the 100 MAs, is the 100 mAs does not switch on middle of that light is always bright.
Please help me.Thanks!
The Following User Says Thank You to lilida For This Useful Post:
Old 02-21-2009, 10:26   #52 (permalink)
Member: 393468
Thanks Meter: 17
nk3650 was dead.flase and formet set on but now prob is here when call any number set restart and off what is the prob please post here as soon as
The Following 3 Users Say Thank You to tcs1337 For This Useful Post:
Old 02-22-2009, 13:16   #53 (permalink)
Member: 975998
Sonork: shahi
Thanks Meter: 2
thanks u r keeping well so keeping
The Following 2 Users Say Thank You to M.shahid imran For This Useful Post:
Old 02-22-2009, 18:25   #54 (permalink)
Member: 977732
Sonork: harmandeep45
Thanks Meter: 6
nokia 6120 c
bro i have an problem with 6120-c , i flashed that mobile once but it get stop after the last stage of rebooting and i try it again the phone the phone never get flahed can u help me it says
cant sync with phone , i even cheack other cabel but same .
one thing more it was dipped in water
please helpppppp
The Following 2 Users Say Thank You to Harmandeep45 For This Useful Post:
Old 02-23-2009, 16:05   #55 (permalink)
Member: 403881
Thanks Meter: 80
Originally Posted by digitized View Post
check shoting in nokia 1650,1200,1208......
1..remove this coil mark in (1)..if u want to check the light ic is short....
2..remove ringer ic mark in (2)..if u want to check shoting remove it and check if shoting is gone replace it because ringer ic also got +b volt from battery....
3..remove the network ic n7100 mark in (1)...if u want to check this ic is short remove it and check shoting...if it is shot then replace it...
4..at end check the power ic d2901 mark in (4) and reemove it to check shoting is there or not...
all the component which are mark in pink colur these all are coils these are place in series and +b of batery is gone throw them so if u remove the coil u not have to remove ic to check the shorting in pcb it save time and ur ic ....
digitized...
[email protected]
Removed all the component marked but still bord is showing shot.
Regards,
The Following 3 Users Say Thank You to sarojrkl For This Useful Post:
Old 02-23-2009, 19:55   #56 (permalink)
WAJID PNR's Avatar
Member: 625961
Sonork: 100.1590447
Thanks Meter: 1,285
Check avilma section inside steel cotting
Old 02-24-2009, 06:40   #57 (permalink)
digitized's Avatar
Member: 163833
Sonork: 100.1579554
Thanks Meter: 5,700
Regards,
remove power ic & then check it....
The Following 3 Users Say Thank You to digitized For This Useful Post:
Old 02-24-2009, 15:33   #58 (permalink)
Member: 83767
Thanks Meter: 3
hi friends i have 6280 when i open camra the masage come stand by mod and phone hang..........i m to much worry sadeed
The Following User Says Thank You to taxila_77 For This Useful Post:
Old 02-24-2009, 16:01   #59 (permalink)
Member: 580966
Sonork: 100.1590311
Thanks Meter: 725
Smile 6280 camera solution
Check this friend it work 100%
tested by me.
W.b.r
Karan
The Following 23 Users Say Thank You to KK Mobile For This Useful Post:
Old 02-25-2009, 00:45   #60 (permalink)
Member: 969769
Thanks Meter: 3
thanks man... your d best....more power..
The Following 2 Users Say Thank You to bochot_2009 For This Useful Post:
Page generated in 0.20363 seconds with 10 queries
