11-10-2006, 21:54 | #5 (permalink) |
Insane Poster Join Date: Sep 2004 Age: 50
Member: 83879 Status: Offline Thanks Meter: 4 | Ist check ur mobile with sw.Select 6600_full erase.fia in mcu & flash the mobile.If mobile full erase & shows right flash addresses than there is no need to change any flash ic.After that flash mobile with latest firmware available,write good pm,init sim, full fact & format. Ater complition of this job if mobile is in same position than replac N380 near batt conn.If mobile is in same condition than change RAM ic. |
sir which flash ic are compatibility for 1650 | bijugreat | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 07-22-2009 17:45 |
i want to know what is the procedure to change 5300 flash ic? | hooi76 | Nokia Hardware & Hardware Repair | 0 | 06-30-2009 05:32 |
which flash ic has imei no on it? | shafeek | Nokia Hardware & Hardware Repair | 2 | 11-25-2006 00:57 |
i have 3310 i want to convert it to 3330,i am not geting eeprom ic and flash ic 3330 | LVVINE | Nokia Hardware & Hardware Repair | 6 | 08-15-2004 23:55 |
