Old 08-29-2011, 08:20   #1 (permalink)
Registered User
Member: 410877
Thanks Meter: 34
Arrow x3 ui setting failed usb ok
Number of Image Files: 3
Processing Image File :
rm540__08.54.mcusw
CMT Type : BB5
CMT Algorithm : XSR 1.6
Secondary Sending Speed : 3250000Hz
Algorithm Sending Speed : 6500000Hz
Program Sending Speed : 19500000Hz
Message Reading Speed : 98000Hz
Number of Blocks : 136
Entry Point: 0x0259
Page Format : -1
MAX PAGE : 0x00040000
rm540__08.54.ppm_cib
CMT Type : BB5
Number of Blocks : 24
Entry Point: 0x011D
Page Format : -1
rm540__08.54.image_cib_059C1G8_003
CMT Type : BB5
Number of Blocks : 63
Entry Point: 0x0154
Page Format : -1
AUTO SELECTED DEAD USB FLASHING...
If Flashing DOES NOT Start in 5 Seconds,
Then Perform Steps 1, 2, 3 and 4...
1. Remove USB and Battery...
2. Insert USB.
3. Insert Battery. (Some phones boot automatically)
4. Please Power on phone shortly...
AdvanceFBox SendBootCodeEx
InitialiseBootstrap_DCT5 DIR
BootFlashMode_DCT5
BootRom Verified!
BootFlashModeDCT5Ex Succeeded First Time
SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned
Number of Sub Blocks 7 (0x07)
1 SYSTEM_ASIC_ID 01
Block Length : 21 (15)
BB ASIC Index : 0 (00) CMT
ID DWORD 0 : 00000001
ID DWORD 1 : 00000226
ID DWORD 2 : 00000001
ID DWORD 3 : 020C1921
ID DWORD 4 : 02034100
2 ROM_ID 15
Block Length : 5 (05)
ID DWORD 0 : 00001040
3 ROM_ID 15
ID DWORD 0 : 00001030
4 PUBLIC_ID 12
ID DWORD 0 : 13300311
ID DWORD 1 : 05540E49
ID DWORD 2 : 14866D1D
ID DWORD 3 : E27F0588
ID DWORD 4 : 624950FF
5 ASIC_MODE_ID 13
Block Length : 2 (02)
Mode Id : 00
6 ROOT_KEY_HASH 14
Block Length : 17 (11)
Hash : 7B 04 54 00 E1 75 20 22 F9 EB 80 B0 DE A9 C6 5D
7 ROM_ID 15
Block Length : 9 (09)
CRC 0 : 67E82268
CRC 1 : F29CEA60
START FLASHING
RawLoaderExtract: rm540__08.54.mcusw
CMT Secondary Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\BB5_USBLoaders\RAP3Gv40_2 nd.fg
Secondary Loader Sent....
MCU_CONFIGURATION_RESPONSE_BB5:
MessageID : C1
SubBlocks : 06
1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
BB ASIC Index : CMT 00
Device Type : RAM 05
Device Index : 00
Manufacturer Code : 0000 -> Flash
Device ID : 0000 -> not detected
Extended/Fixed ID : 0000
Revision ID : 0000
2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Type : MMC 04
Device Index : 00
Manufacturer Code : FFFF -> Flash
Device ID : 0000 -> BAD FLASH TYPE
Revision ID : 0000
3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Type : NOR 00
Device Index : 00
Revision ID : 0000
4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Index : 01
Manufacturer Code : 0000 -> SPANSION
Device ID : 0001 -> not used
Revision ID : 0000
5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Type : MuxOneNAND 03
Device Index : 00
Manufacturer Code : 00EC ->
Device ID : 0030 -> K5W1G13ACB
Revision ID : 0321
6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5
Block Length : 09
Data :
SearchForBootstrap_DCT5 : No Error - 0 (0x00)
Flash Descriptor
Device ID : 0030
Revision ID : 0000
Size : 08000000 (128 MB)
VPP Info : 0000
Erase10s : 1E
Block1s : 32
BErase1s : 02
Reserved0 : 00
Reserved1 : 00
Reserved2 : 00
CMT Algorithm Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\BB5_USBLoaders\RAP3Gv40_X SR17_alg.fg
Algorithm Loader Sent...
FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready)
FUR control Ok
Pabub KEY Request
PhoneInfoRequest_BB5 (Asic Index 00 )
PHONE_INFO_RESPONSE_BB5
PAPUB_KEYS_HASH_RESP_BB5 2A
BB Asic Index : 00
CMT PAPUBKEYS HASH:
CEFA9C410038BD7D17C4C6F107F1EC02C98CA69E
ImagePath: C:\Program Files\Nokia\Phoenix\Products\RM-540\
ImageFilename: rm540__08.54.mcusw
Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01)
Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only)
Certificate 1
ASIC Index : CMT 0
Certificate 2
ASIC Index : CMT 0
Certificate 3
ASIC Index : CMT 0
Certificate 4
ASIC Index : CMT 0
STORE_CERTIFICATE_REQUEST_BB5 : 61 04 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 D3
STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00)
ProcessPartitionInfo_DCT5...
Partition Info
Partition Blocks : 1
1 PARTITION_INFO_BB5
BB ASIC Index : 0x00 CMT
Device Type : 0x03 MuxOneNAND
Device Index : 0x00
Partition Version : 00010000
Spare : FFFFFFFF
Num Partitions : 00000004
Partition 1
Attribute : 00000002 RO
Start Address : 000A0000
Partition 2
ID : 00000008 FILESYSTEM
Attribute : 00000001 RW
Start Address : 02CC0000
Partition 3
Start Address : 077C0000
Partition 4
Start Address : 07B40000
PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000010000FFFFFFFF00000004000000030000 0002000A000002720000000000080000000102CC000004B000 000000000A00000001077C0000003800000000000B00000001 07B4000000180000C9
PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00)
ProcessPartitionInfo_DCT5 : No Error - 0 (0x00)
StartErase_DCT5...
BlockLength : 0xE1 (225)
ERASE Blocks : 0x04 (4)
0 ERASE_AREA_BB5 0x12
Block Length : 0x4B (75)
Device Index : 0x00
0 : 00020000-000203FF
1 : 00060000-0009FFFF
2 : 000A0000-0025FFFF
3 : 003E0000-005DFFFF
4 : 005E0000-010DFFFF
5 : 01EC0000-01EDFFFF
6 : 027C0000-02CBFFFF
7 : 077C0000-07B3FFFF
8 : 010E0000-01EBFFFF
1 FORMAT_PARTITION_BB5 0x19
Block Length : 0x2F (47)
Device Index : 0x00
Format Info ID : 0x02000000
Format Info : 00000000000000080000000000000002000000640000000200 000002000000010000000000000000
2 FORMAT_PARTITION_BB5 0x19
Device Index : 0x00
Format Info : 000000000000000A0000000100000002000000640000000200 000002000000010000000000000000
3 FORMAT_PARTITION_BB5 0x19
Device Index : 0x00
Format Info : 000000000000000B0000000000000002000000640000000200 000002000000010000000000000000
ERASE_REQUEST_BB5 : 5009120B00030000020000000203FF120B0003000006000000 09FFFF120B000300000A00000025FFFF120B000300003E0000 005DFFFF120B000300005E0000010DFFFF120B00030001EC00 0001EDFFFF120B000300027C000002CBFFFF120B000300077C 000007B3FFFF120B000300010E000001EBFFFF3D
FORMAT_REQUEST_BB5 : 5001192F000300000000020000000000000008000000000000 00020000006400000002000000020000000100000000000000 003E
FORMAT_REQUEST_BB5 : 5001192F00030000000002000000000000000A000000010000 00020000006400000002000000020000000100000000000000 003B
FORMAT_REQUEST_BB5 : 5001192F00030000000002000000000000000B000000000000 00020000006400000002000000020000000100000000000000 003B
Successfully erased..
Total blocks to write : 136
>> CMT Rootkey Hash CERT : ADA
>> CMT Rootkey Hash CERT : KEYS
>> CMT Rootkey Hash CERT : PRIMAPP
>> CMT Rootkey Hash CERT : PASUBTOC
>> CMT Rootkey Hash CERT : PAPUBKEYS
>> CMT Rootkey Hash CERT : RAP3NAND
>> CMT Rootkey Hash CERT : UPDAPP
>> CMT Rootkey Hash CERT : DSP0
>> CMT Rootkey Hash CERT : MCUSW
>> CMT Rootkey Hash CERT : MCUSW1
>> CMT Rootkey Hash CERT : GENIO_INIT
>> CMT Rootkey Hash CERT : ISA+DYNSW
ImageFilename: rm540__08.54.ppm_cib
StartErase_DCT5...
BlockLength : 0x0E (14)
ERASE Blocks : 0x01 (1)
Block Length : 0x0B (11)
Device Index : 0x00
0 : 01EE0000-027BFFFF
ERASE_REQUEST_BB5 : 5001120B00030001EE0000027BFFFF74
Total blocks to write : 24
ImageFilename: rm540__08.54.image_cib_059C1G8_003
StartErase_DCT5...
BlockLength : 0x3F (63)
ERASE Blocks : 0x02 (2)
Device Index : 0x00
0 : 02CC0000-077BFFFF
Device Index : 0x00
ERASE_REQUEST_BB5 : 5001120B00030002CC0000077BFFFF90
Total blocks to write : 63
ContinueFlash_DCT5 Complete
Continue Flash Complete : : No Error - 0 (0x00)
Status_BB5 STATUS_REQUEST_BB5..
1 Sub Block ID : 15 STATUS_NAND_OK_BB5
Block Length : 0F
BB ASIC Index : 00
Device Type : 03
Device Type : 00
Num Bad Blocks : 00000002
Additional Bad : 00000002
Correctable ECC : 00000000
FlashInfo.RestartMode : 2
Flashing Done...
Total Flashing Time (Erase + Flashing) : 00:01:00
(Booting time is NOT Included)
Waiting for Phone to Start-Up..(Max 150 seconds)
Elapsed Time: 5 Seconds...
Elapsed Time: 10 Seconds...
SW: V 08.54 25-10-10 RM-540 (c) Nokia
IMEI: 351536045993753
CONFIG KEY: 0000000000000000
PROVIDER KEY: 2440700000000000
Provider : AT&T;U.S.A. (3650)
Counters : 0/3 , 0/10
Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open
SP Lock Status : Not Locked
SIMLOCK_TEST : PASSED
SECURITY_TEST : PASSED
SUPER_DONGLE_TEST : PASSED
SECURITY_CODE : 12345
SL3 Phone detected
* Firmware Version Downgrade will KILL PHONE !!!
* Manual Full Erase WILL KILL PHONE!!!
* Simlocks are in PM 120 Only...
* PM 308 is Write Protected...
FACTORY SET TO : Full Factory Set
OK
FACTORY SET TO : User Data
OK
FACTORY SET TO : Leave Factory
OK
FACTORY SET TO : Service Center
OK
FACTORY SET TO : Software Upgrade
OK
FACTORY SET TO : Production Tune
OK
RESET LIFE TIMER TO : 0000:00
OK
Help to connect data cable to notebook throught USB casper Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 06-21-2001 14:08
MAD2 instruction set Frodo Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 06-04-2001 11:23
MCU EEPROM contents: failed phr3ak Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 02-12-2001 15:58
Nokia 5110 v. 5.24 Unlock Failed! Cybertooth Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 02-28-2000 15:35
Mti init failed dogbreak Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 11-22-1999 01:28
Page generated in 0.23257 seconds with 9 queries
