04-29-2004, 00:48 | #1 (permalink) |
Insane Poster Join Date: Dec 2000 Location: Pila, Poland
Member: 2710 Status: Offline Sonork: 113620 Thanks Meter: 0 | Glued UEM working solution - continuation First time it takes long, but if you learn this solutin it goes very easy and fast. Now i need maximum 15-20 to change gluted IC. On the beginnng i tried to pick up gluted Ic in many ways but always PCB was damage, one or two tracks were broken. Plese post your results, Im curios that my solution is working. Here are promised photos taken yesterday: Photo 1 Photo 2 Photo 3 Photo 4 Photo 5 BeSt ReGreeDs BoDziO [email protected] |
04-29-2004, 09:42 | #4 (permalink) |
No Life Poster Join Date: Feb 2002 Location: burning phones
Member: 9700 Status: Offline Thanks Meter: 62 | @Bodzio: Interesting... but you never destroy pads with the grinder? I use other method, but not safe... with wnife and hot air... insert knife behind glue and ic... and pull up. (15% times broke pad) and after, remove glue with knife and 180º (like u) b.r. |
04-29-2004, 21:23 | #6 (permalink) | |
Member: 2710 Status: Offline Sonork: 113620 Thanks Meter: 0 | Quote:
BeSt ReGreeDs BoDziO [email protected] | |
04-30-2004, 09:49 | #8 (permalink) |
Member: 9700 Status: Offline Thanks Meter: 62 | Thanks Bodzio, I will try this week. I have Dremmel... but I want first to buy the support platform for a better precision. @renejeic: go to his yahoo group, sign up as a member and you will download pics withouth problems b.r. |
05-01-2004, 02:00 | #11 (permalink) |
No Life Poster Join Date: Sep 2003 Age: 66
Member: 39601 Status: Offline Thanks Meter: 13 | @Everybody ... Those photos are Bodzio's Photos from 1 to 5 at the top of the thread , they'r not mine ! . I restores them from my 'temporary internet files ' folder for the persons complaining from dead links |
05-01-2004, 05:31 | #12 (permalink) |
No Life Poster Join Date: Oct 2001 Location: -------- Age: 55
Member: 7062 Status: Offline Thanks Meter: 126 | hi. this way is not complete safe 100% cuz it migt reach the efficincy after destroy many pcb and this is my personal cooment 1- the drill is un easy to control 2- the powder from the ic while drilling is goes every where and cuz big mess 3- the components around the uem is very small and near 4- the tip of the drill you use is very expinsive and you can use one tip every 3 or 4 ic's . 5- the old fashion ay is more safe and its take time less than drilling way take . i m not attach hat wat but advise ppl with what i faced br., |
05-01-2004, 12:13 | #13 (permalink) |
Member: 39601 Status: Offline Thanks Meter: 13 | Yes I add my voice to raheeeeb's , we test it allready ourselfs ( raheeeeb & myself ). That judjement doesnt come from nothing . Add one important thing , is that the diameter of the balls ( 0.3 mllm ) will not be equall in parallel connecting the IC to the PCB because of drimmelling variable depth from corner to corner . But noproblem it is a good tryall but we may take the risck sometimes |
05-01-2004, 12:35 | #14 (permalink) |
No Life Poster Join Date: Sep 2000 Location: Netherlands
Member: 2100 Status: Offline Thanks Meter: 40 | I also tried this solution a while ago, and some problems like raheeb and Medz point are true. Also the powder-dust is in my workshop in every corner, not to mention the health, maybee these IC's are in a "cancer" chemicals (or perhaps the glue?) For the "cornering" problem I was thinking to buy a support tool that hold the dremel firmly in place (with depth control) In a solderjig, it sould be possible to do the job more accurate |
05-03-2004, 07:50 | #15 (permalink) |
No Life Poster Join Date: Apr 2002 Location: Radiometer Medical ApSBrønshøj Age: 51
Member: 10854 Status: Offline Sonork: 1578988 Thanks Meter: 3 | @gsmen That's the way... CNC drill is not so expensive, works much faster and there is no chance to damage board ( unless it's not firmly tighten in seat )... Plus, it has vacuum to suck in all dust... You can build one easily... Few stepping motors, pc interface and application to control coordinates... Or even you can buy LEGO kit and adapt it to hold modeling drill BR Vule |
After removal of glued UEM and glued uem removal video guide | Raheeeeb | Nokia Repair Guide and FAQ | 254 | 06-19-2019 01:40 |
removing glued uem | telkomsa159802 | Nokia Hardware & Hardware Repair | 2 | 09-23-2004 07:29 |
Gluted UEM working solution !!! | Bodzio | Nokia Hardware & Hardware Repair | 7 | 04-29-2004 05:50 |
6100 glued UEM. The end of repar is near??? | Renda | Nokia Hardware & Hardware Repair | 8 | 11-26-2003 16:45 |
Glued UEM in 6310i | mis | Nokia Hardware & Hardware Repair | 9 | 10-01-2003 13:56 |
