06-15-2003, 12:37 | #1 (permalink) |
Insane Poster Join Date: Apr 2002 Location: Denmark
Member: 10692 Status: Offline Thanks Meter: 0 | HELP :3310 waterdamaged. I cleaned it using ultrasonic bath. Now it turn on showing Contact Service immediately. (it does not show insert card first then C.S.) I rehoot cobba. It does not help. Then I rehoot COBBA, Flash, RAM, Hagar and CCONT. Now it is totally dead! Any help Thanks |
06-17-2003, 21:51 | #2 (permalink) |
Freak Poster Join Date: Jul 2002 Location: MAD Age: 50
Member: 13545 Status: Offline Thanks Meter: 2 | first u should check sleep clock ... and the go to ccont values ...is it ok .. and then 26 mhz is it working ..."u can check it using frequency counter" and then check HAGAR ... and also go to flash "change or reball" |
06-18-2003, 14:27 | #3 (permalink) |
No Life Poster Join Date: Jan 2002 Location: freak land Age: 44
Member: 8866 Status: Offline Thanks Meter: 50 | from now on try to heat only one IC then pw on ...then other...and so on.. not all at once ... at this point u must reball all of them and then see what`s next... |
06-18-2003, 15:02 | #4 (permalink) |
Member: 10692 Status: Offline Thanks Meter: 0 | @jokkergsm: Thanks for your advice. Iam new at reballing. I tried to reball the BGA using metal mask and solderpasta. When heeting the solder I got a lot of good balls. but a few jump away. the result is that there are missing 5-6 balls. We will appreciate if you could tell exactly how to make good balls. What is the best/good way to clean solder from board and bga ic, when removing. many thanks mate |
help [ANSWERED] | mariusgsm76 | Nano-Box | 2 | 04-01-2010 11:33 |
Waterdamaged W810i can't connect | Crazy_ratata | Cruiser Suite | 4 | 09-27-2006 21:07 |
fixing waterdamage | partytubie | Siemens Hardware Repair Area | 3 | 09-08-2006 16:34 |
w800 wont unlock after waterdamage | btl | Sony Ericsson Hardware Repair | 3 | 03-20-2006 20:04 |
t 100 waterdamage | alanmar | VLSI, Conexant, Skyworks and Old Models | 1 | 02-15-2004 09:59 |
