12-09-2004, 22:27 | #1 (permalink) |
No Life Poster Join Date: Feb 2003 Location: In My Pub
Member: 307549 Status: Offline Thanks Meter: 188 | Help With Changeing 6600 uem i need to change the uem and imei on 6600 this is how i thought u do it 1. make ask from 6600 2. change uem for new uem 3. .ask 2 RPL file 4. upload new RPL file to 6600 ive being told this is wrong ifit is can someone please tell me were im going wrong thanks |
12-10-2004, 22:31 | #3 (permalink) |
No Life Poster Join Date: Jun 2002 Location: CTSA Age: 46
Member: 12660 Status: Offline Thanks Meter: 7 | Hi mark845 your on the right track you only need to make an *.ask file if you want to keep the same IMEI number , If not then scrap that Idea the hardest part is removing the UEM as it is glued (underfill) If you succesfully remove it without damaging the board then the rest is simple try use bga adhesive remover then replace with blank UEM then when connected to your box it should go into local mode (NOKIA) on LCD then write UEM with asic 5 *.rpl you might need to unlock it as well even though it does it after writing UEM but I find sometimes you have to do it manually like on 3200 WBR D. |
12-17-2004, 13:09 | #7 (permalink) | |
Member: 307549 Status: Offline Thanks Meter: 188 | Quote:
Thanks calvinpower Im useing the twister box mate, could u please tell if i need to make an ask then get that calcultated? or do i just upload any asic 5 rpl file to the blank uem mate? thanks for the help | |
12-18-2004, 17:45 | #8 (permalink) | |
No Life Poster Join Date: Mar 2004 Age: 67
Member: 58052 Status: Offline Thanks Meter: 21 | Quote:
12-18-2004, 18:27 | #9 (permalink) |
Member: 12660 Status: Offline Thanks Meter: 7 | @ mark845 You only need to make an *.Ask file if you want a specific IMEI or the original one back you can upload any asic5 *.rpl the the 6600 and then it will have the imei of the *.rpl file you wrote to it and this of course can only be done one time Regards D. |
12-18-2004, 18:58 | #10 (permalink) | |
Thanks DMD mate and every one else THANKS | |
12-18-2004, 20:34 | #11 (permalink) | |
Member: 58052 Status: Offline Thanks Meter: 21 | Calculate Ask Quote:
COULD U PLS EXPLAIN TO ME HOW TO REWRITE A CERTAIN IEMA STEP BY STEP I AM USING A TORNADO BOX- THE REASON WHY I AM ASKING IS BECAUSE I HAVE HAD A FEW DCT4 PHONES LATELY WITH ?????????4 and everbody is telling me to just calculate the ask file and reflash and all will be fixed but i just cannot get it right many thanx len | |
12-19-2004, 10:06 | #12 (permalink) |
Member: 12660 Status: Offline Thanks Meter: 7 | Hi cellcity When you have the handset connected to the Tornado you click on the Read Uem button then you will get a pop up box where it asks if the IMEI is correct your's should have ??????????????? then you need to enter the correct IMEI from the back casing of the handset you cannot remove cable from phone for this purpose or else it won't complete the *.Ask file so write down the number you might also need to enter the product code as well Regards D. |
12-20-2004, 18:48 | #13 (permalink) |
Member: 307549 Status: Offline Thanks Meter: 188 | Hi guys thanks for all the help, there is just one moer theing, someone told that when u change the 6600 uem you need to also change the flash ic aswell is this right? ive changed the uem in my 6600 but now the phone does not responed at all, my twister box does nnot pick it up at ?? any ideas what this could be thanks once agin |
12-23-2004, 16:10 | #14 (permalink) |
Freak Poster Join Date: Mar 2004 Age: 54
Member: 56617 Status: Offline Thanks Meter: 4 | Did u write the rpl file ? m8 u said u changed the uem ? right ? It could be the UEM is not ok .. for that reason the mobile is not on again .. the UEM as I know is the power IC .. so replace with a good quality one and post what happend ANAN KUWAIT |
12-24-2004, 09:20 | #15 (permalink) |
Member: 307549 Status: Offline Thanks Meter: 188 | @ mohd_anan thanks for that yes it did replace nad no i hva eupload the rpl as i cant get twister to work wiht the phone now, is there anyway to tell if the uem is good or not? |
help with nokia 6600 flashing problem | nasuib | WD2 & APE (Symbian Phones) | 2 | 10-26-2007 03:55 |
help with nokia 6600 | braveheat | Nokia Hardware & Hardware Repair | 1 | 08-16-2006 10:34 |
Help With Crazy 6600 | geosan1638 | Twisterflasher | 10 | 03-19-2005 22:54 |
Help with change IMEI on T68i | unlockmax | Sony Ericsson | 5 | 10-24-2003 09:58 |
need help with changing IMEI on BE4 v138, please help | pali | Alcatel & TCL Old Models | 0 | 06-13-2002 18:23 |
