11-27-2011, 20:43 | #1 (permalink) |
Junior Member Join Date: Feb 2004 Location: algeria Age: 46
Member: 55107 Status: Offline Thanks Meter: 0 | help me plz 4 2220s help me plz DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0.00V MSID-Crypted: 840C07F9E345571A98B2950C89 MSID-Plain: 2C40BAE900D6BC0DAA000000 FAID-Crypted: DCCF849917AE3E55D3475AC2 Flashbus Write baud set to 6.50Mbits 2 Region(s) to erase Erasing NOR Region [0x01000000-0x0101FFFF] Erasing NOR Region [0x01020000-0x01CFFFFF] Erase taken 118.406s Writing 176 blocks... Block Write Failed -> Chunk Data Cheksum failed at AE0775 (26-81) Box VPP disabled Processing Flash Image Failed -> Write failed Failed to Flash -> Problem with processing MCU Image file Processing pre-flash tasks... Pre-flash tasks finished Booting UPP... UPP ID: 3168 [HW_UNKNOWN] rm590__10.25.mcusw, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 Box VPP disabled Internal Box VPP Enabled PLL Factor: 3 FlashChip[0]: 0x0020883C @ 0x01000000, ST, SectorSize: 128kB, Ext: 00009321 FlashChip[1]: 0x0020883C @ 0x02000000, ST, SectorSize: 128kB, Ext: 00009321 Signature: AD7EB61B23100340C605E40120A20000 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 51Kbits u3_intel.fia, Type: Algorithm, Target: FlashChip[0] 0x0020883C (256Mbits), Rev: 7.4.80.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 4.83V MSID-Crypted: 840C07F9E345571A98B2950C89 Using MSID-FAID Cache, Not wasting card FAID-Crypted: DCCF849917AE3E55D3475AC2 Flashbus Write baud set to 6.50Mbits 2 Region(s) to erase Erasing NOR Region [0x01000000-0x0101FFFF] Erasing NOR Region [0x01020000-0x01CFFFFF] Erase taken 118.328s Writing 176 blocks... Block Write Failed -> Chunk Data Cheksum failed at AE0775 (26-81) Box VPP disabled Processing Flash Image Failed -> Write failed Failed to Flash -> Problem with processing MCU Image file |
11-27-2011, 21:34 | #2 (permalink) |
Member: 55107 Status: Offline Thanks Meter: 0 | Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic] Initializing box... Box Firmware: Cyclone Nokia/Blackberry Application v01.82, (Nov 12 2011 09:45:38, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2011 Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs Box Serial Number:*** HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2008, wk27 Initializing security card... Card Serial Number: **** Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 4.90v PASSED MCU Voltage 3.29v PASSED Core Voltage 1.79v PASSED VBAT Voltage 1.36v PASSED VBAT Voltage 4.90v PASSED Box VPP disabled VPP Voltage 0.00v PASSED Internal Box VPP Enabled VPP Voltage 4.83v PASSED Box VPP disabled VPP Voltage 0.04v PASSED External Box VPP Enabled VPP Voltage 0.04v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE XGold/Blackberry Service Running, Credits Left: 100 Avaiable Physical Memory: 258.556MB Avaiable Virtual Memory: 1.392GB Avaiable Pagefile: 1.92GB Initializing FBUS... All initialized - Ready to work Processing pre-flash tasks... Pre-flash tasks finished Booting UPP... UPP ID: 3168 [HW_UNKNOWN] rm590__10.25.mcusw, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 Box VPP disabled Internal Phone VPP Selected PLL Factor: 3 FlashChip[0]: 0x0020883C @ 0x01000000, ST, SectorSize: 128kB, Ext: 00009321 FlashChip[1]: 0x0020883C @ 0x02000000, ST, SectorSize: 128kB, Ext: 00009321 Signature: AD7EB61B23100340C605E40120A20000 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 51Kbits u3_intel.fia, Type: Algorithm, Target: FlashChip[0] 0x0020883C (256Mbits), Rev: 7.4.80.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0.04V MSID-Crypted: 840C07F9E345571A98B2950C89 MSID-Plain: 2C40BAE900D6BC0DAA000000 FAID-Crypted: DCCF849917AE3E55D3475AC2 Flashbus Write baud set to 6.50Mbits 2 Region(s) to erase Erasing NOR Region [0x01000000-0x0101FFFF] Erasing NOR Region [0x01020000-0x01CFFFFF] Erase taken 118.312s Writing 183 blocks... All blocks written OK! Time taken 69.32s Terminating flash session Box VPP disabled Booting UPP... UPP ID: 3168 [HW_UNKNOWN] rm590__10.25.image_m_a_graphi, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 Box VPP disabled Internal Phone VPP Selected PLL Factor: 3 FlashChip[0]: 0x0020883C @ 0x01000000, ST, SectorSize: 128kB, Ext: 00009321 FlashChip[1]: 0x0020883C @ 0x02000000, ST, SectorSize: 128kB, Ext: 00009321 Signature: AD7EB61B23100340C605E40120A20000 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 51Kbits u3_intel.fia, Type: Algorithm, Target: FlashChip[0] 0x0020883C (256Mbits), Rev: 7.4.80.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0.00V MSID-Crypted: 846826785AEDA6E3C7EA343854 MSID-Plain: D26EBAF100D6BC0DAA000610 FAID-Crypted: C34302A7B028A29B63DBE6D9 Flashbus Write baud set to 6.50Mbits 2 Region(s) to erase Erasing NOR Region [0x02180000-0x02E7FFFF] Erasing NOR Region [0x02E80000-0x02FBFFFF] Erase taken 130.172s File Sector Size: 128kB, Flash Chip Sector Size: 128kB CNT Convertion not needed Writing 320 blocks... All blocks written OK! Time taken 32.375s Terminating flash session Extracting Content Package... CP Extract Failed -> Phone not detected WARNING: Failed to extract CP Box VPP disabled Booting UPP... UPP ID: 3168 [HW_UNKNOWN] rm590__10.25.ppm_m_a, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 Box VPP disabled Internal Phone VPP Selected PLL Factor: 3 FlashChip[0]: 0x0020883C @ 0x01000000, ST, SectorSize: 128kB, Ext: 00009321 FlashChip[1]: 0x0020883C @ 0x02000000, ST, SectorSize: 128kB, Ext: 00009321 Signature: AD7EB61B23100340C605E40120A20000 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 51Kbits u3_intel.fia, Type: Algorithm, Target: FlashChip[0] 0x0020883C (256Mbits), Rev: 7.4.80.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0.02V MSID-Crypted: 847265FAD5B5708837DD9F2D7C MSID-Plain: 3E4EBAE900D6BC0DA8000000 FAID-Crypted: 378421113B23A3F3EEB11243 Flashbus Write baud set to 6.50Mbits 1 Region(s) to erase Erasing NOR Region [0x01D00000-0x0217FFFF] Erase taken 41.688s Writing 33 blocks... All blocks written OK! Time taken 12.328s Terminating flash session Box VPP disabled Processing post-flash tasks... Setting Factory Defaults... dead mobile ???????????????? |
Winlock 1.10 - Help | rdmfs | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 06-25-1999 08:21 |
