Old 03-24-2013, 10:23   #1 (permalink)
Member: 608516
Sonork: 100.1607007
Thanks Meter: 123
x2-00 dead
here is hwk log
Insert USB Cable to Switched OFF Phone and Power ON
USB BOOT : 56,06 [Rm-618] [2.2.0.3]
CMT ASICID: 000000000000000022000509200C0000
EM 1 ID : 00005361
CMT PUBID : 00000000008E530CB59A1C6694D323EFFB2606C1
CMT MODE : 00
CMT HASH : 1B0D74C532CA1C6133940C740E8C786E
CMT ROMID : DE56D582BDDE7A3A
CMT 2ND Bt: BCM21351_usb2nd.fg, Ver: 11.34.0
ERR: CMT 2ND Boot TRTY_REQ Fail
IMAGE : rm618__08.35.mcusw
Process Failed, Repowering Mobile
The Following User Says Thank You to cheeni For This Useful Post:
Old 03-25-2013, 00:46   #2 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
try with other flashing device
also chk cable
if still same
reball flash ic
Old 03-25-2013, 00:57   #3 (permalink)
Member: 1259860
Thanks Meter: 7
flash by flash v8.25
Old 09-05-2013, 05:20   #4 (permalink)
Registered User
Member: 1779439
Sonork: n/a
Thanks Meter: 3
Originally Posted by cheeni View Post
here is hwk log
EM 1 ID : 00005361
CMT MODE : 00
hi,try mild heat flash ic
then check ui settings and flash highest version original firmware
done using hwk
Old 09-05-2013, 05:39   #5 (permalink)
kathirmobiles's Avatar
Member: 1591177
Thanks Meter: 85
here is hwk log
EM 1 ID : 00005361
CMT MODE : 00
bro any time best for nokia tool ATF you flash high ver for atf solve your problem
Old 09-05-2013, 05:44   #6 (permalink)
Member: 1671566
Sonork: 100.1645138
Thanks Meter: 21
flash with 8.35 version
Page generated in 0.16638 seconds with 8 queries
