Old 09-04-2013, 10:04   #1 (permalink)
Member: 1576549
Thanks Meter: 2
Red face HELP! Nokia 101 LCD Blank White Screen
Hello Experts...
This forum is very great, keep up the good work. But pls i need possible solution for a problem on the Nokia 101 (Dual SIM). It dropped in water and has been cleaned and working. The screen started showing blank white. But after replacing with another screen, it worked but the blank white screen fluctuats in atimes. If it turns white, if i switch it off and on... it displays normal and goes back White after some minutes. Please someone help me with the solution. Would really appreciate. Thanks
Old 09-04-2013, 15:40   #2 (permalink)
Sagitarious's Avatar
Member: 615730
Thanks Meter: 256
OK brother first clean good your PCB and try this solution. Post result...
File Type: jpg nokia 101 white display problem solution.jpg (113.9 KB, 117 views)
Old 09-04-2013, 16:58   #3 (permalink)
Member: 1576549
Thanks Meter: 2
Thanks, i really appreciate but the Phone would not power on with the jumper.
But powers when the jumper is removed...
Any other try?
Old 09-04-2013, 17:21   #4 (permalink)
Member: 1610218
Change LCD or check LCD track.......100% track will break
Old 09-04-2013, 17:41   #5 (permalink)
Member: 1576549
Thanks Meter: 2
Thanks, but please could you please shed more light?
What dyou mean by LCD Track?
100% Track will break... I dont understand.
Old 09-04-2013, 22:54   #6 (permalink)
r a nadeem's Avatar
Member: 241039
Thanks Meter: 4,170
Check pic and links
Rashid Ahmed Nadeem
Page generated in 0.14229 seconds with 9 queries
