06-21-2013, 12:07 | #1 (permalink) |
Insane Poster Join Date: Feb 2011 Location: tandag city
Member: 1511040 Status: Offline Thanks Meter: 10 | help nokia n73 fast drain battery... i have here, nokia n73 i test battery connector its not shorted...then i put fully charged battery only 1 hour...even if it is not use,..fast drain... thanks........ br, |
06-21-2013, 13:41 | #3 (permalink) |
Freak Poster Join Date: May 2012
Member: 1759693 Status: Offline Thanks Meter: 54 | The battery drain problem is quite difficult to solve. To solve this we need to change betty ic. It may result to set dead. It is better to return to the customer or try the best. N73 is the battery eating set..... |
06-22-2013, 08:07 | #4 (permalink) |
No Life Poster Join Date: Feb 2012 Location: kanpur
Member: 1722956 Status: Offline Sonork: mybestfriend.adeel Thanks Meter: 305 | Chek yourset with out sim card.if battery not drain it means pa problem.change pa. If without simcard set now drain bettery it means betty ic or bluetooth IC problem , change bitty ic OR BLUETOOTH IC.Dont think about set dead. It normaly proccess to change betty ic or any other ic.if you have any problem to change any ic contect me on yaoo. I give you some tricks. |
06-22-2013, 10:10 | #6 (permalink) | |
Member: 1722956 Status: Offline Sonork: mybestfriend.adeel Thanks Meter: 305 | Quote:
if you change ic there are two condition of set dead- 1- ic is damage 2-you did not reboll ic correctly. but it have no mean that set is parmanent dead. try again when u reboll ic correctly and set it on board corretly your mobile will be okk. | |
