01-15-2004, 15:23 | #1 (permalink) |
Freak Poster Join Date: May 2003 Location: In between some long female legs
Member: 28095 Status: Offline Thanks Meter: 0 | Nokia 6600 - No Screen Light, camera not working I believe this is due to slight liquid damage to the phone, this has also stopped the LCD from lighting up. The LCD works fine, not missing bits or anything, just no backlight. The question i am asking is, can this be repaired, or would i need another screen and camera ?? The mainboard of the phone has been gone over with on the worst parts with a fibre glass pencil to eliminate any short circuit. Should i put this in the ultrasonic tank to clean it properly ?? Any help would most appreciated Regards NaaN |
01-15-2004, 21:59 | #2 (permalink) |
No Life Poster Join Date: Sep 2003 Age: 66
Member: 39601 Status: Offline Thanks Meter: 13 | Well , actually the water dammadged PCBs is hazardly diagnosed and terated . Beside U'r phone is still new ( I still have no schematics ), but I think that the problem may be in the screen board itself , if U can check with other LCD,also cleaning the board is vital. |
01-16-2004, 09:56 | #3 (permalink) |
Member: 28095 Status: Offline Thanks Meter: 0 | hi, thanks for the reply, i have checked the small connector ribbon with 4 conenctions that comes off the side of the LCD im assuming that is for the LCD bacjklight. Upon close inspection i realised that one of the conenctions has corroded away due to the oxidisation, i am in the process of fixin the track using conductive silver paint. So hopefully i will be able to get the backlight fixed (touch wood!!) Only problem left is the camera, i am highly doubtful that it can be opened and cleaned as it seems like a sealed unit. If anyone can tell me otherwise i would be mose appreciative Regards NaaN |
01-16-2004, 21:21 | #4 (permalink) |
Freak Poster Join Date: Dec 2003 Location: E G Y P T Age: 47
Member: 45635 Status: Offline Thanks Meter: 20 | about screen light problem ! the same problem i found at 6610 & 7250 , and i solved it by changing a small coil at the back of mainboard beside battery socket , i think that ur problem will be solved if u searching about this coil (i dont know where it is at 6600 adjustly) |
01-16-2004, 22:55 | #5 (permalink) |
Member: 39601 Status: Offline Thanks Meter: 13 | @Majestic Pirate. The coil U mensioned is a new hardware feature comes with the " colored screens ". It is the - matching up voltage source - to give 18 Volt or near to the colored screens ( Up Dc to Dc converter ). |
01-17-2004, 10:11 | #6 (permalink) |
Member: 28095 Status: Offline Thanks Meter: 0 | woo hoo, screen now fixed but i think camera is dead!! Anyone know how i can test/repair the camera unit ?? If not where i can get a new one from ?? Cheers for your helo NaaN |
07-02-2004, 13:35 | #7 (permalink) |
No Life Poster Join Date: Jul 2003 Location: BahaMAS Age: 40
Member: 35975 Status: Offline Thanks Meter: 19 | HOW DID YOU FIX THE SCREEN NaaN? And where is this coil on 6600? I have same problem with water damage 6600 but set is not powering on sometimes! Any help?? tonytony |
07-02-2004, 19:00 | #9 (permalink) |
Freak Poster Join Date: Nov 2003
Member: 44625 Status: Offline Thanks Meter: 36 | It may be tough to get a camera for the phone, except maybe from an authorized nokia repair centre. And u can be sure it won't come cheap. If u r lucky it may just be corroded tracks of some other components not workin around the camera. |
11-10-2004, 23:30 | #10 (permalink) |
Freak Poster Join Date: May 2002 Location: none Age: 49
Member: 11926 Status: Offline Thanks Meter: 0 | I have same problem with a 6600 display I already resoldered the LCD contacts on lcd and on phone board, but I still have no back light. Can anyone tell me wich is that coil and where is it located. NaaN : can you please post a picture pf wich contacts you soldered ??? ius that little connector on the back of the lcd ??? Thks to all |
12-31-2004, 03:30 | #11 (permalink) | |
Junior Member Join Date: Sep 2004 Age: 47
Member: 81584 Status: Offline Thanks Meter: 0 | Quote:
this may look similar to earlier post but i am having the ditto same problem so its again I have same problem with a 6600 display when opened i saw an ant lie died on the contacts of screen , i removed her but i saw the very first contact broken bcos of this . I already resoldered the LCD contacts on lcd and on phone board, but I still have no back light. Can anyone tell me wich is that coil and where is it located. NaaN : can you please post a picture pf wich contacts you soldered ??? ius that little connector on the back of the lcd ??? Thks to all Last edited by dr_ankur24; 01-01-2005 at 03:31. | |
NOKIA 2630, network, bluetooth & camera not working | ameerali19 | Nokia Hardware & Hardware Repair | 36 | 06-27-2010 01:13 |
nokia 6101 no screen light | de brain box | Nokia Hardware & Hardware Repair | 1 | 01-08-2010 08:33 |
Nokia n73 after flash now camera not work, why and how to solve? | svchost | HWK | 3 | 01-06-2010 03:55 |
Nokia 6600 Joy Stick Up key not working | Saleemsmj | Nokia Hardware & Hardware Repair | 4 | 12-20-2009 13:31 |
730sc after reset all settings, No Signal & Camera not work | rea1One | Z3X-Team Products | 12 | 05-06-2009 22:58 |
