Old 01-15-2004, 15:23   #1 (permalink)
Member: 28095
Nokia 6600 - No Screen Light, camera not working
Hi, have a nokia 6600, currently when switched on and the camera is selected it says "hardware failure"
I believe this is due to slight liquid damage to the phone, this has also stopped the LCD from lighting up. The LCD works fine, not missing bits or anything, just no backlight.
The question i am asking is, can this be repaired, or would i need another screen and camera ??
The mainboard of the phone has been gone over with on the worst parts with a fibre glass pencil to eliminate any short circuit.
Should i put this in the ultrasonic tank to clean it properly ??
Any help would most appreciated
Regards
NaaN
Old 01-15-2004, 21:59   #2 (permalink)
Member: 39601
Thanks Meter: 13
Well , actually the water dammadged PCBs is hazardly diagnosed
and terated .
Beside U'r phone is still new ( I still have no schematics ), but I
think that the problem may be in the screen board itself , if U can
check with other LCD,also cleaning the board is vital.
Old 01-16-2004, 09:56   #3 (permalink)
Member: 28095
hi, thanks for the reply, i have checked the small connector ribbon with 4 conenctions that comes off the side of the LCD im assuming that is for the LCD bacjklight.
Upon close inspection i realised that one of the conenctions has corroded away due to the oxidisation, i am in the process of fixin the track using conductive silver paint. So hopefully i will be able to get the backlight fixed (touch wood!!)
Only problem left is the camera, i am highly doubtful that it can be opened and cleaned as it seems like a sealed unit. If anyone can tell me otherwise i would be mose appreciative
Regards
NaaN
Old 01-16-2004, 21:21   #4 (permalink)
Member: 45635
Thanks Meter: 20
about screen light problem !
the same problem i found at 6610 & 7250 , and i solved it by changing a small coil at the back of mainboard beside battery socket , i think that ur problem will be solved if u searching about this coil (i dont know where it is at 6600 adjustly)
Old 01-16-2004, 22:55   #5 (permalink)
Member: 39601
Thanks Meter: 13
@Majestic Pirate.
The coil U mensioned is a new hardware feature comes with the
" colored screens ".
It is the - matching up voltage source - to give 18 Volt or near to
the colored screens ( Up Dc to Dc converter ).
Old 01-17-2004, 10:11   #6 (permalink)
Member: 28095
woo hoo, screen now fixed but i think camera is dead!!
Anyone know how i can test/repair the camera unit ??
If not where i can get a new one from ??
Cheers for your helo
NaaN
Old 07-02-2004, 13:35   #7 (permalink)
TONYTONY's Avatar
Member: 35975
Thanks Meter: 19
HOW DID YOU FIX THE SCREEN NaaN? And where is this coil on 6600?
I have same problem with water damage 6600 but set is not powering on sometimes!
Any help??
tonytony
Old 07-02-2004, 14:20   #8 (permalink)
Member: 28095
I took the screen apart and found that the contacts were corroded so i resoldered them and repaired them best i could!
Thanks
NaaN
Old 07-02-2004, 19:00   #9 (permalink)
Member: 44625
Thanks Meter: 36
It may be tough to get a camera for the phone, except maybe from an authorized nokia repair centre. And u can be sure it won't come cheap. If u r lucky it may just be corroded tracks of some other components not workin around the camera.
Old 11-10-2004, 23:30   #10 (permalink)
Member: 11926
I have same problem with a 6600 display
I already resoldered the LCD contacts on lcd and on phone board, but I still have no back light.
Can anyone tell me wich is that coil and where is it located.
NaaN : can you please post a picture pf wich contacts you soldered ??? ius that little connector on the back of the lcd ???
Thks to all
Old 12-31-2004, 03:30   #11 (permalink)
Member: 81584
Unhappy
Thanks
NaaN
hey dear
this may look similar to earlier post but i am having the ditto same problem so its again
when opened i saw an ant lie died on the contacts of screen , i removed her but i saw the very first contact broken bcos of this . I already resoldered the LCD contacts on lcd and on phone board, but I still have no back light.
Thks to all
Old 12-31-2004, 16:11   #12 (permalink)
smartecs's Avatar
Member: 42370
Thanks Meter: 32
for the camera problem i think it is not 1.8v to operate it,try to check the camera power supply
NOKIA 2630, network, bluetooth & camera not working ameerali19 Nokia Hardware & Hardware Repair 36 06-27-2010 01:13
nokia 6101 no screen light de brain box Nokia Hardware & Hardware Repair 1 01-08-2010 08:33
Nokia n73 after flash now camera not work, why and how to solve? svchost HWK 3 01-06-2010 03:55
Nokia 6600 Joy Stick Up key not working Saleemsmj Nokia Hardware & Hardware Repair 4 12-20-2009 13:31
730sc after reset all settings, No Signal & Camera not work rea1One Z3X-Team Products 12 05-06-2009 22:58
Page generated in 0.24484 seconds with 9 queries
