01-13-2014, 15:32 | #1 (permalink) |
Freak Poster Join Date: Jan 2010 Location: JANGAON-AP
Member: 1197753 Status: Offline Sonork: [email protected] Thanks Meter: 32 | How to remove and install IC on cellphone |
01-13-2014, 17:01 | #2 (permalink) |
No Life Poster Join Date: Jul 2005 Location: karachi
Member: 161728 Status: Offline Sonork: 100.1582708 Thanks Meter: 2,237 | These are basics u need tools: hot air machine iron soldering wire soldering paste bga paste bga plates tweezer last but not the least "S K I L L S" without skills and practice all above tools are useless now come to the point how to remove ic ? Set heat and air (depends on u) put some flux (paste) on ic now give heat all around on ic when u feel that bubbles under ic melting ,use tweezer and slightly shake the ic carefully now this is the time to pull up the ic after removing ic ,use iron to clean the bubbles from the ic and from pcb... Now we come to point how to reball ic,for this u use bga plate and bga paste,this need experience and practice... After reballing ,finally this is the time to fix the ic again,but again as i said above,all this need experience,skills,patience,hardworking and practice... I m still learning and i try my best to guide u,but hope other members guides u much better than me |
The Following User Says Thank You to HUM For This Useful Post: |
01-13-2014, 18:26 | #3 (permalink) |
Moderator Join Date: Jul 2006 Location: Midnapore,West-Bengal,India
Member: 322206 Status: Offline Sonork: 100.1594813/.:SARCAR:. Thanks Meter: 1,350 | @birruvijay , quite offtopic post , but anyway u may search on google or youtube for videos . u can find lots of videos how to remove,reball & install bga ic's . practice on dead scrape boards to improve ur skills & knolwdge . |
The Following User Says Thank You to .:SARCAR:. For This Useful Post: |
