08-10-2003, 01:19 | #1 (permalink) |
Junior Member Join Date: Aug 2003
Member: 36704 Status: Offline Thanks Meter: 0 | How to remove PA? I have to heat the whole metal covering the PA and remove it, the problem is to remove the PA, because it may break it self. What is the best way? |
08-10-2003, 16:36 | #4 (permalink) |
Freak Poster Join Date: Oct 2002 Location: Egypt Age: 57
Member: 17337 Status: Offline Thanks Meter: 12 | try to use raidio shak flux it is the best also you can remove the flam by taking it out strongly but with care don't need to heat it because some times is dengrouse and you have the risk to move one of the small risestant from its place |
08-10-2003, 20:00 | #7 (permalink) |
Member: 36704 Status: Offline Thanks Meter: 0 | u just have to pull it up whit small pliers. start to pull it up here there is only a small piece of metal in contact with the PCB and then move on to the next u will see that once one piece of metal is disconected from the PCB, the outher will offer no resistence |
08-13-2003, 07:29 | #11 (permalink) |
No Life Poster Join Date: Apr 2002 Location: Radiometer Medical ApSBrønshøj Age: 51
Member: 10854 Status: Offline Sonork: 1578988 Thanks Meter: 3 | You won't break anything if u r careful enough...On 8210 i never heated frame in order to remove it...And i never put it back after repair...On 3310 i just cut out piece that covers area where i have to replace components... BR Vule |
how to remove MMC Password remove? | gajanan57 | Nokia Hardware & Hardware Repair | 6 | 03-01-2012 12:25 |
How to Remove "Mobile Tracker" in J800 & also How to Flash? | rajinder1978 | UST Pro II | 1 | 12-18-2009 08:03 |
C450: How to remove privacy without removing sms's | dannyogolo | NSPRO | 4 | 06-15-2008 20:58 |
How to remove a working PA without any damage | hs_ | Nokia Hardware & Hardware Repair | 2 | 10-31-2002 07:16 |
How To Remove Pa Successfully | Black-Axe | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 07-20-2002 14:50 |
