i nedd nokia x2-02 insert sim solution i nedd nokia x2-02 insert sim solution................................ |
1 Attachment(s) Quote:
try trick image below good luck and only thank button |
change sim ic only pro sol |
hi bro i change sim ic and rehot power ic but still same problem any more sul......? |
nokia x2-02 insert sim solution 1 Attachment(s) nokia x2-02 insert sim solution with pic........... |
thnxxxxx good job but its deficul |
same problem plzzzzzzzzzzzzzzzzz help me |
1 Attachment(s) hello , check above sim way first , if sim ways ok & same problem after replace sim esd filter then try t replace dual sim swap ic . (marked in attach picture) please post here result . (dual sim swap ic bypass not possible atm) |
i changed sim ic and changed sim controlar.i have flashed set and also reboll ibfinion power ic but same in insert sim problem. any master have solution? a impoertnr things.a long time takes this mobile to appear insert sim. |
check vsim voltage , it should be 1.8v-2.8v refer schematics for vsim voltage test point . post result |
is there problem from power ic????? |
2. Check ways from power ic to sim slot. 3. Check shortage in this ways. Voltage must be Logic is the iron made. |
have you any image to prove your commment?????????????? |
2. Sim connector is standart unit, therefore you may use any schematics to solve your problem. 3. I'm show part of X2-00 schematics, try to solve problem. http://fotohost.kz/images/2013/12/12/vR7fs.png Logic is the iron made. Usefull post? Than press http://fotohost.kz/images/2013/11/14/7roYR.gif |
