Lumia 735 Charging Way Hi Guys, have a Lumia 735 which wont charge with USB. Changed USB Connector already without Success. The Phone charging with Wireless Charger, but not with USB. Is there an IC which I can bridge? |
1 Attachment(s) hi , first check vchg in voltage at J3300 , it's about dc 5v there . if voltage is ok then remove V3300 (marked in attach picture) & short it's two points A1+A2 (described in attach picture) connect charger & check if still same problem then remove both Z3300 & Z3302 (marked in picture) . if problem still remain then you need to replace charging regulator V3301 (marked in attach picture) . post result |
Thanks :) Will check it |
V3300 bridge 100% worked. Thanks a Lot ! |
