02-17-2017, 17:05 | #1 (permalink) |
Insane Poster Join Date: Apr 2012 Location: Germany
Member: 1752885 Status: Offline Thanks Meter: 4 | Lumia 735 Charging Way have a Lumia 735 which wont charge with USB. Changed USB Connector already without Success. The Phone charging with Wireless Charger, but not with USB. Is there an IC which I can bridge? |
The Following User Says Thank You to mimk97 For This Useful Post: |
02-17-2017, 18:49 | #2 (permalink) |
Moderator Join Date: Jul 2006 Location: Midnapore,West-Bengal,India
Member: 322206 Status: Offline Sonork: 100.1594813/.:SARCAR:. Thanks Meter: 1,350 | hi , first check vchg in voltage at J3300 , it's about dc 5v there . if voltage is ok then remove V3300 (marked in attach picture) & short it's two points A1+A2 (described in attach picture) connect charger & check if still same problem then remove both Z3300 & Z3302 (marked in picture) . if problem still remain then you need to replace charging regulator V3301 (marked in attach picture) . post result |
The Following 4 Users Say Thank You to .:SARCAR:. For This Useful Post: |
02-20-2017, 11:18 | #5 (permalink) | |
Junior Member Join Date: Apr 2014 Location: philippines
Member: 2177078 Status: Offline Sonork: family Thanks Meter: 2 | Quote:
