03-06-2002, 05:16 | #1 (permalink) |
Junior Member Join Date: Mar 2002 Location: pinas Age: 49
Member: 9949 Status: Offline Thanks Meter: 0 | 6210 & 3210 charging problem i got 6210 (slightly water contaminated on component side of the PCB),the prob is that the battery indicator still running after disconnecting the charger... no visual sign of open traces and via holes are clear from corrosion. already replaced N100 and N101, also checked some RCs related to charging ckt.... lastly, the 3210 charging problem, the battery indicator is just blinking when the charger is connected, using a known good battery. the board is clean and i already did some repair around charging ckt.,but to no avail... maybe u have some specific opinion on these. tnx n advanz. best regards. Last edited by tagoy; 03-06-2002 at 05:24. |
03-06-2002, 13:23 | #2 (permalink) |
No Life Poster Join Date: Jun 2001 Location: UAE Age: 43
Member: 5019 Status: Offline Sonork: 100.110196 Thanks Meter: 69 | 3210 For 6210: i have this problem too on my 3310 searching for good solution For your 3210 try Hotair near between BatterConnectors or replace that capacitor and resistor between batter connector, work for me 100% GoodLuck! |
03-07-2002, 18:45 | #4 (permalink) |
Member: 9949 Status: Offline Thanks Meter: 0 | thanks for the info mates. I already fixed one 3210, i manually resoldered all chips around ccont and charging ctrl IC... ty arc. but, i still has one 3210 with the same problem that i couldn't fix with the same sol'n. i'll just try your advise later rem, i do really appreciate it. about your 3310 arc, i encountered a lot of that,due to water damaged, but was not able to fixed them coz of lack of schemes.but probably, it cud just be an open pattern along the via holes. WANTED: 3310 schematic.... is there anybody who can share its pdf file to me? i would be grateful to have it... more power everybody.... bstrgrds |
Nokia 3210 charging problem | YamahaR1 | Nokia Hardware & Hardware Repair | 17 | 08-17-2012 14:36 |
Nokia 3210 charging problem | Batgoy | Nokia Hardware & Hardware Repair | 4 | 01-14-2003 18:03 |
3210 charging problem | j_h_u_n | Nokia Hardware & Hardware Repair | 4 | 08-10-2002 04:12 |
3310, 3210 charging problem | patrynio | Nokia Hardware & Hardware Repair | 2 | 07-15-2002 00:41 |
3210 charging problem???? | sawa | Nokia Hardware & Hardware Repair | 1 | 12-28-2001 09:46 |
