11-02-2002, 18:28 | #4 (permalink) |
Freak Poster Join Date: Aug 2002 Location: __inside__ Age: 41
Member: 14792 Status: Offline Thanks Meter: 1 | if it doesnt detect the charger..check fuse and charge connector...and then L100/101,R100/101 and C146..but it says "not charging"let me know..__jero__ |
11-17-2002, 17:19 | #9 (permalink) |
No Life Poster Join Date: Mar 2000 Location: inside NOKIA phone Age: 58
Member: 1060 Status: Offline Thanks Meter: 10 | Chuk, Why not you remove L100 ,then plug charger, and measure voltage R103 both side TO MAKE SURE THAT R103 DEAD ? Just remove it ? if R103 dead, have to replace it ,,, can not just remove it ! WIlly |
11-18-2002, 09:07 | #10 (permalink) |
No Life Poster Join Date: Dec 2001 Location: Ukraine Age: 46
Member: 7767 Status: Offline Thanks Meter: 3 | I agree with You. But You no need to place it, because it just peak voltage protection (approx. 30V). Ofcourse, better to replace it, but if You'll use original charger - all will be OK without it. Problem is not in replaceing or removeing - problem is where to get new one.... (old and dead phones is not the solution). Why I need remove L100, when I can measure R103 resistance? PS: This is one little thing (R103), that missing in 3210 troubleshoots from Nokia. May be problem in it? We need good repair instructions!!!!! We can't think sometimes (not for You, Willy). Last edited by Chuk; 11-18-2002 at 10:34. |
11-18-2002, 10:42 | #11 (permalink) | |
Member: 7767 Status: Offline Thanks Meter: 3 | Re: Nokia 3210 charging problem Quote:
If You remove R103 from this PCB and measure it, You'll see, that I'm right, Satelite hacker..... | |
11-18-2002, 14:45 | #12 (permalink) |
Member: 1060 Status: Offline Thanks Meter: 10 | Satelite hacker Chuk maybe you are right . @Why I need remove L100, when I can measure R103 resistance? @It's R103 short. Just remove it from pcb. 100% tested. remove L100, it mean to cut off line connect from FUSE to CHAPS , then when you can plug a charger , and make test that "short" or not ! Willy |
11-18-2002, 15:17 | #13 (permalink) |
Freak Poster Join Date: Jun 2002 Location: TUNISIA Age: 62
Member: 13122 Status: Offline Thanks Meter: 0 | R103 removed and still not charge i have short circuit between F100 to both side of R103 I test on working 3210 this short circuit exist (F100 and down side of R103) |
11-18-2002, 15:44 | #15 (permalink) | |
Member: 7767 Status: Offline Thanks Meter: 3 | Quote:
R103, C114, C163, C108, C100, N101. I test on working 3210 this short circuit exist (F100 and down side of R103) Yes, but one side only (not grounded). Are You shure, that You remove R103, but not L100? Visually, there are the same. If You have short circuit after N101 (10 Ohm between VCHOUT and Gnd) - check C122 (10u/10v) Last edited by Chuk; 11-18-2002 at 15:56. | |
Nokia 3210 charging? | mzabbasi79 | Nokia Hardware & Hardware Repair | 0 | 02-10-2009 12:52 |
nokia 3210 charging stops after 10seconds | crossings | Nokia Hardware & Hardware Repair | 2 | 01-29-2003 04:05 |
Nokia 3210 charging problem | Batgoy | Nokia Hardware & Hardware Repair | 4 | 01-14-2003 18:03 |
6210 & 3210 charging problem | tagoy | Nokia Hardware & Hardware Repair | 3 | 03-07-2002 18:45 |
3210 charging problem???? | sawa | Nokia Hardware & Hardware Repair | 1 | 12-28-2001 09:46 |
