mixed up keys on 3510i I have a 3510i that has mixed up keys, I flashed twice and cleaned the pcb, it seems not be water damage, any idea what can I do? Thanks in advance. |
not software problem clean board using wd40, find ic (6 legs) for keys near cpu and reflow it |
Man what version u flash??? seem like wrong version.. |
1 Attachment(s) wow ... wd40 ... great idea, will work for sure ... but 10-15days and after that, acid contained in wd40 will start "eating" all metal parts you sprayed .... :) i say this because i saw many 3310 sparayed with wd40 ... and ... they looked like somebody washed them in sulphur acid :) and the real solution for 3510i mixed keys problem is : short explanation : there are 2 different board versions one "normal" ... you can flash and reflash ANY version and all will work fine ... and second one ... different, which after flashing with newer or the same FW version will give mixed keys problem ... solution is to write only a good PM file into phone and all will work well. tested on many phones, especially phones from comviQ, sweden. here's the PM file ... write to phone and do init simlocks b.r. ALexandar. |
Ha Ha Brka Whats wrong with u don't u like WD40 ? :) :) We all know its just a software issue :) Regards D. |
of course it's a SW issue and wd40 ... well, it can make hardware issue ;) hehe b.r. ALexandar. |
jsut go to make HW ID before 2000 or lafter 2000 ! and WD40 ,,, never try to use it clean PCB ! Willy |
WD40 is great stuff when your cars alternator gets wet or the hinges on your house door get sticky but using it on handsets is just F@cking Mad Regards D. |
of course, thats what it's made for. not for phones, of course. b.r. alexandar. |
