08-10-2002, 04:13 | #3 (permalink) |
Freak Poster Join Date: Feb 2002 Location: Jakarta
Member: 9261 Status: Offline Thanks Meter: 0 | signal lost is very very complex problem. so if you want to repair it, you must be carefull and slowly and step by step. the first check simple problem like connector antenna, sim card connector, batery connector & board position. its all ok, you must testing to replace one by one your chip: 1. PA (power amplifier) 2. Switch Antenna 3. haggar 4. cobba 5. ccont but don't forget, signal lost can be repair using software. so try to repair with software first. good luck................... |
7650 unstable signal solutions ??? | hendraz | WD2 & APE (Symbian Phones) | 1 | 03-16-2007 18:03 |
siemens c35i unstable network signal solution | mosesma | Siemens Hardware Repair Area | 1 | 08-23-2005 19:25 |
n3210 signal always ok,but..... | fiZ | Nokia Hardware & Hardware Repair | 3 | 09-29-2002 06:59 |
N3210 signal holds 5 sek | fiZ | Nokia Hardware & Hardware Repair | 5 | 08-26-2002 15:44 |
WARNING !!! N5110, v5.30, N3210 v6.00 | ico | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 11-25-2000 23:34 |
