02-16-2010, 17:07 | #1 (permalink) |
Junior Member Join Date: Sep 2008
Member: 866948 Status: Offline Thanks Meter: 0 | N70 blank MCU SW : V 05wk07v48.1 28-08-07 RM-84 (c) Nokia. APE Core: APE Var : Prd.Code: 0530431 Bpr.Code: 0522156 Prod.Sn : CIJ687446 HW Vers : 6061 APE HW : APE Adsp: EM RETU : 32 EM TAHVO: 52 RFIC Ver: 150a160f DSP Vers: rolf_05wk07v29p1 IMEI : 353269-01-700118-5 SL Serv : SIMLOCK SERVER VERSION 58 SL Conf : 244-07-00000000000 SL Prof : 0000000000000000 SL Count: 00 00 BLK1= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK2= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK3= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK4= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK5= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK6= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK7= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN Provider: Nokia Test;Finland |
02-16-2010, 19:41 | #2 (permalink) |
Junior Member Join Date: Jul 2008
Member: 815456 Status: Offline Thanks Meter: 4 | If your N70 can still be used to make calls then it could be hardware fault such as lcd or lcd ic drivers (crystal ic x 2), if it is white screen and hanging then you will have to search forum for solution, I have tried all solution for white screen hanging and only managed to fix 4 n70 like that. good luck my friend, hope you come right. |
The Following User Says Thank You to billycoulson For This Useful Post: |
02-16-2010, 20:35 | #4 (permalink) | |
Freak Poster Join Date: Nov 2007
Member: 629320 Status: Offline Thanks Meter: 47 | Quote:
The simplest N70 blank LCD (non complete booted) solution !!! | mobilagy | Nokia Hardware & Hardware Repair | 29 | 09-05-2010 00:23 |
N70 Blank display and Flash light Very urgent | naseer_10_1980 | Nokia Base Band 5 ( BB-5 ) | 14 | 04-22-2008 21:00 |
N70 blank display | mobilemaster | Nokia Hardware & Hardware Repair | 8 | 02-28-2008 20:54 |
n70 blank lcd | simonmanju | Nokia Hardware & Hardware Repair | 2 | 08-26-2007 11:37 |
N70 Blank Screen | J-lock | Nokia Base Band 5 ( BB-5 ) | 1 | 02-17-2007 14:55 |
