02-10-2007, 00:47 | #1 (permalink) |
No Life Poster Join Date: Mar 2000 Location: next to you ; ) Age: 54
Member: 1133 Status: Offline Thanks Meter: 38 | N70 Camera Problem. Unexpected error occured.Power off the device and restart. Anyone encountered this problem before? Phone is water damaged. When I place back cover and slide it down to use Back camera, I will get error message "Unexpected error occured.Power off the device and restart." However when I DO NOT put back cover and camera is in front camera, it is ok. (After I restart the phone.) I have tested voltage of C1472(4.0V), C1473 (1.5V), R1475 and J1471(1.8V) and seem to be ok. Is it ok for C1473 to have 1.5V since in the service manual, it is suppose to be 2.8V? I checked with 6680 service manual which uses the same N7505(LP3990LDX-1.5NOPB), the correct voltage is 1.5V. Anyway, I have replaced N7505 as well. I have also replaced Camera. Other test is TAHVO to R4408(VIO=1.8V) to S5202 is correct. |
The Following 9 Users Say Thank You to Phantom For This Useful Post: |
02-10-2007, 08:53 | #3 (permalink) |
Member: 1133 Status: Offline Thanks Meter: 38 | Hi reji, Problem solved. It is not a faulty "Level Shifter" (N1474) but just bad contact at I/O_VB1 and I/O_VB2. Thanks for the tip. Cheers. |
The Following 2 Users Say Thank You to Phantom For This Useful Post: |
03-29-2007, 14:13 | #5 (permalink) |
Freak Poster Join Date: Aug 2005 Location: india,mumbai Age: 50
Member: 175555 Status: Offline Thanks Meter: 12 | bro plz can you tell me what this means (I/O_VB1 and I/O_VB2) i can't get u i also have the same problem can u tell me the solution or any picture plz |
The Following 2 Users Say Thank You to imtiyaz For This Useful Post: |
03-30-2007, 05:33 | #6 (permalink) |
Member: 1133 Status: Offline Thanks Meter: 38 | refer to the schematic and look at N1474. You will see the names of the track there. |
03-30-2007, 12:48 | #7 (permalink) |
Member: 175555 Status: Offline Thanks Meter: 12 | plz can u send me the link from where i can downlod n70 sematic diagram i dont have can u plz send it to me i m waiting thanks for ur solution |
The Following User Says Thank You to imtiyaz For This Useful Post: |
03-31-2007, 07:40 | #9 (permalink) |
Member: 175555 Status: Offline Thanks Meter: 12 | i had changed that ic which is near camera jack can u tell me another solution thanks |
03-31-2007, 12:45 | #10 (permalink) |
No Life Poster Join Date: Oct 2006 Location: U A E
Member: 364745 Status: Offline Thanks Meter: 719 | mebe problem camra botten i mean beack cover push the botten and open the camra try 2 change .or some time problem rams try 2 rehot normal .sory english is very poor .br try and send me post result . ..::Mr Fone::.. |
The Following User Says Thank You to ..::Mr_Fone::.. For This Useful Post: |
04-03-2007, 08:20 | #11 (permalink) |
Member: 175555 Status: Offline Thanks Meter: 12 | i had solved te problem of back camera but same error is given when i start front camera any solutio plz plz help thanks for your solution |
"unexpected error occured.power off the device and restart" in NOKIA N82 | ameerali19 | Nokia Base Band 5 ( BB-5 ) | 20 | 12-30-2013 07:15 |
HELP N70 Camera Problem. Unexpected error occured.Power off the device and restart. | digital_wifi | Nokia Hardware & Hardware Repair | 22 | 08-16-2010 22:44 |
unexpected error occurred.power off the device and restart | ameerali19 | Nokia Hardware & Hardware Repair | 2 | 03-08-2010 15:42 |
unexpected error occured.power off the divice and restart in camera`s nokia | ehsan_yeganeh | Nokia Hardware & Hardware Repair | 1 | 01-14-2010 10:31 |
N70 Camera PROBLEM!!Unexpected error occured Power off the device and restart. | kenyap7078 | Nokia Hardware & Hardware Repair | 3 | 02-27-2009 10:24 |
