N70 Display problem Hello everyone, Im having problem with my N70 display, its not full white and lcd is working properly, but i get incresed brightness problem. Phone starts fine, and everything is working properly, no hangs and anything, just this brightness problem. Ive searched forums and didnt find anyone saying anything about solving this issue. Thx in advance. |
2 Attachment(s) Quote:
chak lcd Connecter................... |
n70 display flickering |
Best regards, Ahbab |
try this............... http://xs117.xs.to/xs117/07280/N70_white.JPG |
N70 Just Check The Connector And Driver In Lcd Before Changing The Omap Bro....and The Connection Of The Display In The Connector........ |
regards PUNEET14884 :) |
have u checked ur self.....it never works |
yes it is not work rashid |
dear mukesh_b.Did you read post before answering???? your solution is for dead phones with white screen hanging, But phone in this thread is OK and ON. pls read posts first |
write now the problem is color brightness but the diagaram of ours is used wrongly by a layman? is it clear now the solution for the problem is : * firstly check it with another display then proceed as follows * change the boosting coil but if the prob remains same then * change the lit ic. |
but bro mukesh, in ur pic u said that "remove" both the IC's and apply only one jumper. where is the voltage to the APE? |
yes, u r right but if he removes both smps & ape regulator & makes 1 jumper for vcoreA where from the ape regulater gets voltage, then u have to follow our jumper which is 100% ok. becz ape regulater getz voltage too. |
thk........4 suggestion.........but think before posting atleast.....count does n't matter regards PUNEET14884 :) |
