Old 04-30-2008, 20:15   #1 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
..::n70 fake charging (no charging volts)::..
n70 fake charging(no charging volts) i change tahvo ic,rehot retu,but still very low charging volts,see this picture one print missing,this print cause problem?
..::HUM::..
Old 04-30-2008, 21:47   #2 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
any solution??????????????????
..::HUM::..
Old 05-01-2008, 18:04   #3 (permalink)
Member: 461923
Thanks Meter: 2,020
..change THAVO...work 100%..
Old 05-01-2008, 18:54   #4 (permalink)
smartengghelp's Avatar
Member: 740993
Thanks Meter: 75
if phone is showing charging bars then problem is THAVO ic hange it similar with n72,6680,6681,6630....
br
smartengg
Old 05-01-2008, 19:12   #5 (permalink)
reji's Avatar
Member: 227127
Thanks Meter: 241
RETU has also role in charging, so plz change the RETU.
Old 05-01-2008, 19:53   #6 (permalink)
Member: 428081
Thanks Meter: 5
only change THAVO be ok
Old 05-01-2008, 19:54   #7 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
the set is working ok,the only thing is that when i connect charger some times it show full battery indication sometime continue charging,the battery timing also ok,the only thing with customer is that y it not show full battery indication,
otherwise set works ok.
..::HUM::..
Old 05-02-2008, 08:18   #8 (permalink)
rockgsm's Avatar
Member: 420862
Thanks Meter: 51
Old 07-03-2008, 11:23   #9 (permalink)
Member: 400687
Thanks Meter: 6
change thavo 1000000000%
Old 11-27-2008, 22:47   #10 (permalink)
Member: 276150
Thanks Meter: 75
i tried changing taho but no luck still the volt is low
any new solution please
Old 11-30-2008, 16:37   #11 (permalink)
Member: 700322
masi 786
re hot thavo first then change thavo ic
Old 11-30-2008, 17:00   #12 (permalink)
shuaib_kashish's Avatar
Member: 405715
Thanks Meter: 271
firstly change 'tahvo'.mostly problem will be solve.if problem same then change red marked diode shown in picture.i repaired successfully.
try it and post reply.
wbr
shoeb
The Following 3 Users Say Thank You to shuaib_kashish For This Useful Post:
Old 12-01-2008, 17:57   #13 (permalink)
Member: 647785
Thanks Meter: 24
sir help
sir plz tell me whats the work of pA POWER AMLIFIER AND ANT SWITCH PLZ SIR THANK YOU
Old 12-01-2008, 18:57   #14 (permalink)
azez.sd's Avatar
Member: 735523
Sonork: 100.1591830
Thanks Meter: 262
Thanks man good work................
Old 12-02-2008, 06:56   #15 (permalink)
Member: 278546
Thanks Meter: 145
just change tahvo uoy can take it from another set , becarefull when change tahvo , because over heat will damge other side board omap.take care
..::n70 both charging pads are short with each other & no charge indication::.. HUM Nokia Hardware & Hardware Repair 20 03-05-2015 11:59
Nokia 6310 - No Buzzer, No Vibrator, No charging repairs online Nokia Hardware & Hardware Repair 1 08-15-2007 08:59
K300 no earphone,No mic & No charging RAMSUL Sony Ericsson Hardware Repair 13 10-07-2006 08:21
5210 charging ..no charging help pabloo81 Nokia Hardware & Hardware Repair 1 04-21-2005 17:06
T28s No Charge, No Network, Dark Displey and no Light Sultan Sony Ericsson Hardware Repair 2 05-15-2002 00:57
Page generated in 0.18339 seconds with 10 queries
