Old 08-13-2010, 10:40   #1 (permalink)
Registered User
Member: 669673
Thanks Meter: 301
3110c UI setting failed
nokia 3110c flashing ok but UI setting failed
Old 08-13-2010, 10:56   #2 (permalink)
abdurrahimsagar's Avatar
Member: 734476
Sonork: 100.1604415
Thanks Meter: 2,485
try too jaf box usb i hope your problem solve
The Following User Says Thank You to abdurrahimsagar For This Useful Post:
Old 08-13-2010, 14:01   #3 (permalink)
sunnyarora's Avatar
Member: 483406
Thanks Meter: 180
first flash with 7:30 version if not ok then take backup rpl and erase or flash
Old 08-13-2010, 14:19   #4 (permalink)
aZimBahar's Avatar
Member: 1174508
Sonork: 100.1593820
Thanks Meter: 11,979
try by mx-key . i hope your problem must be solve
Old 08-13-2010, 14:34   #5 (permalink)
Member: 387116
Sonork: 100.1650000
Thanks Meter: 176
1 use jaf
2 format user area
3 full factory
Old 08-13-2010, 15:55   #6 (permalink)
suraj9860607689's Avatar
Member: 787710
Sonork: not using
Thanks Meter: 771
use 7Pin Cable.......
Old 08-13-2010, 17:13   #7 (permalink)
MIRPUR AJK's Avatar
Member: 725834
Thanks Meter: 921
yes dear mr suraj is right this is ur cable falt use 7pin cable ,,,,,,,,,,,,,,,,
Old 05-20-2011, 13:56   #8 (permalink)
Member: 1313317
Thanks Meter: 2
i have a question 7 pin cable is valid for ufs? can use it with mt
Old 05-20-2011, 14:27   #9 (permalink)
rabindar's Avatar
Member: 1277253
Sonork: 100.1617779
Thanks Meter: 33
If not success try to flash with phoniex
Old 05-20-2011, 14:34   #10 (permalink)
Member: 1487057
flas with atf box and see if problem is same then reball tiabo ic 100% ok
Old 05-20-2011, 14:40   #11 (permalink)
Member: 1273701
Sonork: 31121986
Thanks Meter: 2
remove the set &re canect the set
Old 05-20-2011, 14:49   #12 (permalink)
gsmshankarb's Avatar
Member: 1326709
Thanks Meter: 39
flash with 7.30v 1oooo% ok
Old 05-20-2011, 15:02   #13 (permalink)
Registered User
Member: 669673
Thanks Meter: 301
My problem has been solve.
Thanks to all for Support and reply.
MAD2 instruction set Frodo Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 06-04-2001 11:23
MCU EEPROM contents: failed phr3ak Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 02-12-2001 15:58
7110 contrast setting prob... RiddleR Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 07-04-2000 02:53
Nokia 5110 v. 5.24 Unlock Failed! Cybertooth Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 02-28-2000 15:35
Mti init failed dogbreak Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 11-22-1999 01:28
Page generated in 0.17943 seconds with 9 queries
