01-27-2010, 09:34 | #1 (permalink) |
Major Poster Join Date: Sep 2008 Location: Philippines Age: 44
Member: 872423 Status: Offline Thanks Meter: 97 | N70 no lights (open pattern) [SOLVED] Action taken: 1. Clean board 2. try other LCD 3. Change coil (still no lights) 3. remove light I.C.two patterns open(B1 & C2) Solution: JUMPER check schematic diagram, B1 & C2 is open and is connected to L2304(coil) see pictures finish |
The Following 7 Users Say Thank You to charner For This Useful Post: |
01-28-2010, 12:15 | #8 (permalink) | ||
Member: 872423 Status: Offline Thanks Meter: 97 | Quote:
please read carefully got it? Last edited by charner; 01-28-2010 at 12:21. | ||
The Following User Says Thank You to charner For This Useful Post: |
01-29-2010, 06:53 | #9 (permalink) |
Insane Poster Join Date: Nov 2007 Location: INDIA
Member: 640980 Status: Offline Thanks Meter: 20 | ok sir thanks for your advice but the function of light ic is amplifing voltage 4v to 14v when we remove light ic how is it work |
The Following User Says Thank You to mkvineethmk For This Useful Post: |
01-30-2010, 03:36 | #10 (permalink) |
Member: 872423 Status: Offline Thanks Meter: 97 | sir mkvineethmk, i just jumper pin B1 & pin C2 of light I.C. then put it back again because the pad/pattern of B1 & C2 is broken. got it! |
n70 no light | lyepinwah | Nokia Hardware & Hardware Repair | 10 | 11-26-2008 07:40 |
N70 No Light After Flash | david ruan | Nokia Hardware & Hardware Repair | 10 | 07-13-2008 17:55 |
n70 no light no kybad light | FUTURE4ALL | Nokia Hardware & Hardware Repair | 1 | 06-09-2008 00:56 |
n70 no light no kybad light | FUTURE4ALL | Nokia Hardware & Hardware Repair | 3 | 06-08-2008 14:33 |
n70 no light | ebu mohammed-emin | Nokia Hardware & Hardware Repair | 6 | 05-12-2007 19:26 |
