n70 no memory inserted help boss,, good day..i have n70 here the probs is no display and i jump all the connection in crystal ic then it ok..but it cant detect mmc.."no memory inserted"..i tried to jump the mmc ic but still same probs...any other solution please... |
restart your phone after insert the mmc,if it is fine...change the switch near battery connector.then post me result. |
having same problem having same problem but in my case card is working but when open hot swap door it wont msg 'to remove memory card press ok' i have to restart the mobile, i was thinking the same about the hot swap switch what u guys say let me know thnx |
:pmemory card switch replace & shot (2 point short) |
2:momory card switch replace or shote 3:momory card ic volt checking 4:momory card ic replce or short 5:omap rehot |
Hello all! I've the same problem with my N70, but how do you replace the memory card switch?please Many thanks |
