07-28-2008, 10:10 | #1 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Pakistan Peshawar Age: 35
Member: 242264 Status: Offline Sonork: 100.1582011 Thanks Meter: 33 | 1208 hang problem thanks in advance i did try erasing and flashing but not worked for me |
The Following 2 Users Say Thank You to irfan99 For This Useful Post: |
07-28-2008, 10:27 | #2 (permalink) |
Freak Poster Join Date: Apr 2008 Location: every where
Member: 761110 Status: Offline Sonork: 100 0911 Thanks Meter: 45 | Dear brother Irfan 99 just rehot the upp{CPU} if not work remove local mode register or change it I hope u r problem will be solve |
The Following User Says Thank You to nilkamal For This Useful Post: |
08-03-2008, 11:02 | #8 (permalink) |
Moderator Join Date: Jul 2006 Location: Midnapore,West-Bengal,India
Member: 322206 Status: Offline Sonork: 100.1594813/.:SARCAR:. Thanks Meter: 1,350 | friends it's a upp problem just reball or replace upp , your problem will be solved I repaired one set yesterday by replacing upp from other working set post result |
09-01-2008, 10:23 | #9 (permalink) |
No Life Poster Join Date: Jul 2004 Location: KOLHAPUR, MAHARASTRA,INDIA
Member: 71502 Status: Offline Sonork: 100.1650667 Thanks Meter: 587 | 1208 Hang water dameged nokia 1208 when i turn it on after 10 sec. mobile is hang but i connect charger mobile is not hang is this the upp problem or any nokia 2626 type diode solution |
09-02-2008, 01:47 | #11 (permalink) |
No Life Poster Join Date: Jul 2005 Location: karachi
Member: 161728 Status: Offline Sonork: 100.1582708 Thanks Meter: 2,237 | i also got 1208 with same problem,torch on then set works fine................................ so i rehot upp but still same,after that i replace upp and now set is working fine. change upp ur problem will be solved. |
Nokia 1208 Hang Problem..... | farrukh mobiles | Nokia Hardware & Hardware Repair | 29 | 08-31-2014 13:48 |
1208 hang up | yunaced | Nokia Digital Core Technology 4 ( DCT-4 ) | 11 | 11-13-2009 16:51 |
1208 hang problem | jakkarzoya_2511 | Nokia Hardware & Hardware Repair | 6 | 09-12-2008 04:14 |
1208 hang | prime_master786 | Nokia Hardware & Hardware Repair | 7 | 06-24-2008 06:53 |
