Old 01-15-2009, 13:08   #1 (permalink)
^^^RAVI SOOD^^^'s Avatar
Member: 903492
Sonork: 1590666
Thanks Meter: 571
Nokia 6280 /on off switch not warking.....
HI ALL FRANDS.........................
I HAVE NOKIA 6280 ...CHARGING..OK FLASH OK.. BUT NOT POWER ON ...
I CHANGE FLAX AND JACK ALLREADY.....
NO VILTAGE ON 5 PIN (ON/OFF TRACK) ............I TRID EVERYTHNING.....BUT STILL
PLZ HELP..........................
Old 01-15-2009, 13:28   #2 (permalink)
fasany's Avatar
Member: 841015
Sonork: 100.180803
Thanks Meter: 63
pin 36 at b2b conn to j3300 ok or not?
try change keypad ic z3300..
if not ok,better change retu...
Old 01-15-2009, 13:40   #3 (permalink)
Member: 903492
Sonork: 1590666
Thanks Meter: 571
Try change keypad ic z3300..
If not ok,better change retu...
hi::
I change z3300 and rebool retu.. But still .....
More salution.................
Old 01-15-2009, 13:47   #4 (permalink)
fasany's Avatar
Member: 841015
Sonork: 100.180803
Thanks Meter: 63
has u try change it?
if not ok then its must rap3g problem...
Old 01-15-2009, 14:59   #5 (permalink)
Member: 903492
Sonork: 1590666
Thanks Meter: 571
ok i will try .................................................. ....
Old 01-15-2009, 15:09   #6 (permalink)
samirov-gsm's Avatar
Member: 759168
Thanks Meter: 12,866
change other flex...good luck
Old 01-15-2009, 16:27   #7 (permalink)
metro2mobile's Avatar
Member: 515972
Thanks Meter: 526
brother cheak onoff trak any line is open
Old 01-16-2009, 06:49   #8 (permalink)
Member: 903492
Sonork: 1590666
Thanks Meter: 571
i just changed ritu ic and now phone is perfactly warking.......
........ thans mate....
Old 02-09-2009, 16:59   #9 (permalink)
Member: 237670
Sonork: 1604787
Thanks Meter: 13
can you upload picture about retiu ic?
Old 02-09-2009, 21:55   #10 (permalink)
techno-gsm's Avatar
Member: 776884
Sonork: techno-gsm
Thanks Meter: 152
tested by me.......................
http://www.2shared.com/file/4839950/...280_power.html
Old 02-11-2009, 20:13   #11 (permalink)
Member: 385270
Thanks Meter: 2
grait work beg thanks for you
6600 On Off Switch not Working R132 missing broken_rules Nokia Hardware & Hardware Repair 0 12-10-2008 10:56
Nokia 7600 on/off Switch DAMAGED zakiyyboss Nokia Hardware & Hardware Repair 1 09-19-2006 10:31
nokia 6220 on off switch ways pradeep agrawal Nokia Hardware & Hardware Repair 0 08-11-2006 18:04
NOKIA 7270 - on / off switch + chip HELP PLEASE!!! sandrock2005 Nokia Hardware & Hardware Repair 1 03-19-2006 18:00
Nokia 3200 on/off switch pad broken msa Nokia Hardware & Hardware Repair 0 12-13-2004 23:39
Page generated in 0.19146 seconds with 9 queries
