Old 10-13-2007, 09:47   #1 (permalink)
shok9992000@yah's Avatar
Member: 578941
Thanks Meter: 108
Question 3315 auto off when registering to network
friends i got a nokia 3315 automatic switches off when it tries to register to network but when we switch it on with out sim it dosent switches off . what shuld i do shoul i flash it
Old 10-13-2007, 12:09   #2 (permalink)
Member: 367908
Thanks Meter: 15
changa pa.It will work 4 u.
Old 10-13-2007, 12:17   #3 (permalink)
neetika99's Avatar
Member: 588837
Thanks Meter: 146
...no way....change pfo...
Old 10-13-2007, 12:36   #4 (permalink)
Member: 447572
Thanks Meter: 5
Puth of u are correct PA means Power Amplifier and PFO is the
value of d PA.
Old 10-13-2007, 12:36   #5 (permalink)
Member: 447572
Thanks Meter: 5
Both of u are correct PA means Power Amplifier and PFO is the
value of d PA.
Old 10-13-2007, 16:21   #6 (permalink)
Member: 578941
Thanks Meter: 108
can i just remove pfo and make jumpers for it . i have make jumpers for two 3315 both worked successfuly but there the fault was pfo was short.
Old 10-13-2007, 17:45   #7 (permalink)
Member: 275946
Thanks Meter: 8
Thumbs down just solder battery connector in pcb
hey man just solder ur battery connector to pcb ,and its work .ive made more than100 of sets as this system just check it out
Old 10-13-2007, 21:47   #8 (permalink)
delchoni's Avatar
Member: 239176
Sonork: 100.1602815
Thanks Meter: 851
Replace pfo rehot coba and earse flash phone now flash and write pm only ufs and reboting in normal mode !
after this soulutions phone noth worked normaly included this phone in trush!
Old 10-14-2007, 21:40   #9 (permalink)
Dave.W's Avatar
Member: 7653
Thanks Meter: 823
make full flash
update FAId
Clear SP locks
check it
BTW, do not "jumper" PA! are you crazy!
PA is very important for correct operation of the phone! without it you will get network problems, kicked from network. fluctuate signal.
maybe ok when you test, but for customer it will be a big headache!
Old 06-20-2010, 17:31   #10 (permalink)
Member: 1234158
i'm beginner,the picture please......
Old 01-11-2011, 08:31   #11 (permalink)
Member: 1462800
Thanks Meter: 16
pla help any one 3315 on oo off drict on white dispaly any tell me [email protected]
Old 10-15-2011, 09:26   #12 (permalink)
Member: 1623940
Thanks Meter: 22
3315 on off jumper
ways plzzz help me [email protected]
MW930 When registering to network Abzal Infineon C16X M51 & ARM7 M52 BASED 3 07-18-2006 13:41
R210s power off when register to network stanimir_13 Samsung Hardware Repair 6 01-22-2005 09:58
c25 & Motorola Jazz Trips off when Logging to Network dannyogolo Siemens Hardware Repair Area 3 04-17-2003 15:53
a1018 turns off when loggin to network. pali Sony Ericsson Hardware Repair 5 01-25-2003 04:09
SGH-N400 turn off when getting to Network Laser VLSI, Conexant, Skyworks and Old Models 0 03-20-2002 19:26
Page generated in 0.19430 seconds with 9 queries
