Old 03-01-2007, 03:06   #1 (permalink)
Member: 456286
Thanks Meter: 5
Cool N73 NOt charging..
Bro,pls help...I have N73 when you put charger it displays not charging...I try to clean already the charging PIn as well the board...its still not workin...Ca n you give any SOLUTION????thankssss.......
The Following 2 Users Say Thank You to jake007 For This Useful Post:
Old 09-10-2007, 14:00   #2 (permalink)
Crazy Poster
Member: 246869
Thanks Meter: 3
change the fuse or the betty ic bro
The Following User Says Thank You to alltech18 For This Useful Post:
Old 10-07-2007, 23:38   #3 (permalink)
Member: 174626
Thanks Meter: 2
where is fuse on n73?
The Following User Says Thank You to Xtremefones For This Useful Post:
Old 10-08-2007, 04:06   #4 (permalink)
navin71's Avatar
Member: 101891
Thanks Meter: 277
n73 charging solution , please reply back bro
The Following 5 Users Say Thank You to navin71 For This Useful Post:
Old 10-08-2007, 04:27   #5 (permalink)
.::AssAnovic.::'s Avatar
Member: 162611
Thanks Meter: 315
This is the solution friend.........
The Following 4 Users Say Thank You to .::AssAnovic.:: For This Useful Post:
Old 10-08-2007, 08:40   #6 (permalink)
Member: 391370
Thanks Meter: 5
please write pm sir but not full pm
when problem stil the same please replace retu
good luck
The Following User Says Thank You to mohammad ikbal For This Useful Post:
Old 10-08-2007, 10:33   #7 (permalink)
Member: 602754
Sonork: mr
Thanks Meter: 5
brother of mine i have problem of my nokia e65 not charging any sulotion
The Following 2 Users Say Thank You to gfarhan For This Useful Post:
Old 10-08-2007, 10:44   #8 (permalink)
meo786pk's Avatar
Member: 465162
Thanks Meter: 683
Dear,
Check it
Muhammad Afzal Meo
The Following 5 Users Say Thank You to meo786pk For This Useful Post:
Old 01-20-2008, 01:33   #9 (permalink)
Crazy Poster
Member: 155571
Thanks Meter: 2
N73 and E65 not charging
Hi!
There isn't Retu in the N73! So you can't change it...
Check the charging pins. If shorted cut the positive, remove the fuse and make a jumper.
Check Btemp resistor and Btemp value.
Check charging electronic. Maybe 4 or 5 components.
If problem still exists change Betty, and last Avilma!
I had an E65 with charging problem! I changed the betty - nothing. So with me the Avilma can helped!
Of course, the charging problem maybe software or calibration problem, so before you try hardware repair please flash the phone.
If I make a mistake in this steps, please correct me!
Bye, and good luck!
Old 01-22-2008, 04:58   #10 (permalink)
WinD_VteC's Avatar
Member: 647414
Thanks Meter: 127
hello all frenz try change betty is oso cannot charging try change power ic 1000% work for u all.......
WinD
The Following User Says Thank You to WinD_VteC For This Useful Post:
Old 01-23-2008, 11:43   #11 (permalink)
Member: 491612
plzzz send me N91 software
[email protected]
The Following User Says Thank You to ashrafkhan For This Useful Post:
Old 02-15-2008, 08:28   #12 (permalink)
Member: 668919
Thanks Meter: 3
Soo thanks my friend
The Following User Says Thank You to barlas67 For This Useful Post:
Old 02-15-2008, 08:31   #13 (permalink)
Member: 668919
Thanks Meter: 3
thanks masterİts so useful
Old 02-17-2008, 05:49   #14 (permalink)
Member: 473823
Thanks Meter: 10
good job friend thank u
Old 02-18-2008, 10:44   #15 (permalink)
Member: 406810
Thanks Meter: 11
thank you .good......
The Following User Says Thank You to eihab For This Useful Post:
i need Solution n73 not charging GSMJordan Nokia Base Band 5 ( BB-5 ) 3 09-25-2009 14:46
n73 not charging ibraheem0079 Nokia Hardware & Hardware Repair 5 08-03-2009 10:02
N73 Not Charging Need Help Nasmi Nokia Hardware & Hardware Repair 0 06-05-2008 13:25
n93 and n73 not charging....? helin Nokia Base Band 5 ( BB-5 ) 6 10-16-2007 17:26
Help N73 not charging mahdiqaladza Nokia Hardware & Hardware Repair 3 10-12-2007 16:37
Page generated in 0.22307 seconds with 10 queries
