Old 11-10-2008, 16:14   #1 (permalink)
jkniji's Avatar
Member: 643992
Sonork: 100.1625367
Thanks Meter: 180
Arrow Nokia 1200 1st boot not ok by ufs.
Hello all of you my problume is that in Nokia 1200 1st boot not ok . set will drop in to water . i will try it with ufs. and then jaf but no result. any body help me what can i do for this fault. thanks in advance.
The Following User Says Thank You to jkniji For This Useful Post:
Old 11-10-2008, 18:51   #2 (permalink)
Member: 675717
Thanks Meter: 125
First rehot UEM with flux if no good result then rehot UPP with flux if no good result reball UPP if not good reball UEM.Remamber at the first clean the board well.Best of luck.
Old 11-10-2008, 18:53   #3 (permalink)
mohammed-anis's Avatar
Member: 751223
Sonork: mobilecenter88
Thanks Meter: 538
just rehot crystal and uem 100000000000% ok
Old 11-10-2008, 19:00   #4 (permalink)
mobilespeed's Avatar
Member: 706300
Thanks Meter: 147
" bro since it is dropped in water so itz hard to tell u from my place whether the short lies,wt i mean is most parts are involved , so do one thing make it clean & check how much short it possess less the short lesser will be the suspects & vice-versa, so bro check short & post, thanx"
Old 11-10-2008, 19:14   #5 (permalink)
Member: 771625
Thanks Meter: 46
check it if its shorted or not? check if the phone has a current?
if no current you can not software it cant read. check it all?
hope can help?
Old 11-10-2008, 20:14   #6 (permalink)
taieeb's Avatar
Member: 781262
Thanks Meter: 90
keep the board in ipa for two to three hour and then see
Old 11-11-2008, 08:12   #7 (permalink)
Member: 800101
Sonork: 77718
Thanks Meter: 5
this for u
if all yr cable and box are install properly and all in a good conditon, i think you've to open yr phone cover (casing ) than put the software cable and click check if the problem still happen the second trick after click check follow by clicking on botton softly,till Ok.
Do not re hot/ball yr UEM or UPP cause this case is only between your cable, box and flash IC
How we will get your Uem is bad if it doesn't connect, so i suggest u to find it out follow step by step
thanks.
[email protected]
Nokia 6300 1st Boot Err, RAPX NOT BOOTING.." amit123 Nokia Hardware & Hardware Repair 1 09-18-2009 20:57
rh-99 nokia 1200 v5.71 not support by hwk sarasoft CIMO HWK 2 01-16-2009 16:07
nokia 3310 1st Boot Ok, 1st Boot Err: 00 00 subhadara Nokia Hardware & Hardware Repair 3 02-27-2007 18:15
nokia 3310 1st Boot Ok, 1st Boot Err: 00 00 subhadara Nokia Hardware & Hardware Repair 3 02-27-2007 08:54
Nokia 6600 1st boot ok 2nd Error walli Turab Nokia Hardware & Hardware Repair 7 11-27-2006 08:10
Page generated in 0.16650 seconds with 9 queries
