07-24-2008, 06:03 | #1 (permalink) |
Junior Member Join Date: Nov 2006
Member: 387754 Status: Offline Thanks Meter: 11 | n81 no display i tried to change the Lcd and flex but still to luck. still white screen...i also tried to reprogram it but still no luck. please help me with this sir. thanks in advance. |
The Following 2 Users Say Thank You to flasher12 For This Useful Post: |
07-24-2008, 06:06 | #2 (permalink) |
No Life Poster Join Date: Mar 2008 Location: west coast PH
Member: 734668 Status: Offline Thanks Meter: 83 | check if you can call emergency number like 112 if you can then the problem is LCD or maybe flex. If you cannot make a call then its a software problem. |
The Following User Says Thank You to westgold For This Useful Post: |
07-24-2008, 06:28 | #3 (permalink) |
Freak Poster Join Date: Jan 2008 Location: Philippines
Member: 675035 Status: Offline Sonork: [email protected] Thanks Meter: 13 | try another flex sir. |
The Following User Says Thank You to Tongco For This Useful Post: |
09-07-2008, 04:38 | #6 (permalink) |
No Life Poster Join Date: Jan 2007 Location: malaysia
Member: 429569 Status: Offline Thanks Meter: 1,543 | if you outging,,incomeing call ok,,,ur problem is display ic,,,check first one by one,,,lcd,flexi cable,then try display ic,,, all the best |
The Following User Says Thank You to gsmshare For This Useful Post: |
09-08-2008, 02:27 | #8 (permalink) |
Freak Poster Join Date: Aug 2005 Age: 49
Member: 171140 Status: Offline Thanks Meter: 22 | step by step number 1 . power on the phone and wait sec. Is there a voice ringing number 2 . check and info by jaf number 3 . reset factory There may symbol of protection number 4 . Prepared contact the charching Is there a voice |
The Following 2 Users Say Thank You to zazo For This Useful Post: |
11-15-2008, 17:40 | #11 (permalink) |
Freak Poster Join Date: Sep 2008
Member: 856796 Status: Offline Thanks Meter: 40 | i have 1 unit (n81) with the same problem. i already change lcd,,flat cable and lcd ic,,problem just the same,,does anyone have a better idea to solve this,,,,thank you so much |
The Following User Says Thank You to bearhug For This Useful Post: |
06-11-2009, 11:18 | #13 (permalink) |
Junior Member Join Date: Oct 2001 Location: egypt
Member: 6733 Status: Offline Thanks Meter: 0 | hello please help me with the same problem the phone powers on normaly and i can call also it charges i tested the screen on another phone and the flex the lcd works and the flat cable works too on my phone the screen blank and blue i need to know the lcd ic place and what to do thanks |
07-27-2009, 07:44 | #14 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Mirpur-1, Dhaka,Bangladesh
Member: 222009 Status: Offline Sonork: 100.1576751 Thanks Meter: 435 | ohhhhhh same proble me too... I flashed several times but suddenly it appears ok but after 1 day it become withe screen and hang ... I guess no display or rebon problem it's like n70 white hang , bu no solution I found till now !!! |
N81 dark display | woreal.gsm | Nokia Hardware & Hardware Repair | 16 | 03-06-2012 04:58 |
V3 no display,no display light | celluniversal | Motorola P2k | 21 | 11-21-2011 06:57 |
L7 no display and no lights in display, tricks enside.. | ticksjarub | Motorola Hardware Repair | 4 | 09-18-2010 17:30 |
V3 No Display N No Display Light? | jimmyyew | Motorola Hardware Repair | 4 | 05-27-2008 08:33 |
