03-05-2008, 08:22 | #2 (permalink) |
Freak Poster Join Date: Apr 2005 Age: 46
Member: 138020 Status: Offline Thanks Meter: 87 | N93 Overview WCDMA and tri-band GSM/EDGE world phone N93 (RM-55): WCDMA 2100 & EDGE/GSM 900/1800/1900 N93 (RM-153): EDGE/GSM 900/1800/1900 3.2Mega pixel camera with 3x optical zoom, up to 20x digital zoom Video recording with VGA 30fps and play back ****og video signal output with stereo audio via Pop-PortTM Stereo digital microphone Wireless LAN support Mini-SD card support Full-speed USB support Bluetooth Stereo FM radio IrDa N93 BB Structure RAP3GStack/RAPS with PoP2, Vilma and Betty as Cellular engine OMAP2420PoP with PoP3 and Menelaus as Application engine Two camera modules 3.2Mega pixel as main camera CIF as sub camera Two display modules Main display: QVGA 2.4 inch(320 x 240 pixel), 256 k colours Sub display: CSTN (128 x 36 pixel), 64 k colours BTHFM1.0 as Bluetooth and FM radio WLAN size3.0 as wireless LAN module IHF speaker, digital stereo microphone TV-out interface for video signal output Full-speed USB support (No on-the-go support) Mini-SD card support IrDa interface Pop-PortTM connector and 2mm charger plug BP-6M battery |
The Following User Says Thank You to nalkershy For This Useful Post: |
03-05-2008, 08:30 | #3 (permalink) |
Member: 138020 Status: Offline Thanks Meter: 87 | N93 Block Diagram RAP3GS/RAPS RAP3GS ASIC is a stacked version of RAP3G and completely same functionality is implemented as RAP3G. RAPS ASIC is a stacked version of RAPGSM and completely same functionality is implemented as RAPGSM. In general RAP3GS/RAPS consists of: Processor subsystem (PSS) that includes ARM926 MCU as a main processor, Lead3 PH3 DSP and related functions Combo memory module RAP3GS/RAPS core voltage (1.35V) is generated from Betty VCORE and I/O voltage (1.8V) is from Vilma VIO. Core voltage in sleep mode is lowered to 1.05V PoP2 Memory Module PoP2 (Combo memory) module consists of 128Mbit DDR SDRAM memory and 128Mbit NOR Flash memory and is stacked on the top of the RAP3GS/RAPS. This means interface signals between RAP3GS/RAPS cannot be seen cause there’s no tracking on PWB. DDR SDRAM DDR SDRAM is used mainly as a dynamic data storage for MCU data. SDRAM core voltage (1.8V) is generated from Vilma VDRAM and I/O voltage (1.8V) is from VIO NOR flash NOR flash interface is based on DCT-4 Flash interface NOR Flash memory is used to store MCU program code DSP program code Tuning values etc... Logic and supply voltage for NOR Flash is supplied from VIO (1.8V) Vilma Vilma EM ASIC includes following functional blocks: Start up logic and reset control Charger detection Battery voltage monitoring 32.768kHz clock with external crystal Real time clock with external backup battery SIM card interface Stereo audio codecs and amplifiers A/D converter Regulators Vibra interface Digital interface (CBUS) Vilma ASIC does not include security functions such as UEM(E) Betty Betty EM ASIC includes following functional blocks: RAP3GS/RAPS Core supply generation Charge control circuitry Level shifter and regulator for USB/FBUS Current gauge for battery current measuring External LED driver control interface Digital interface (CBUS) Betty ASIC does not include security functions such as UEM(E) OMAP2420 OMAP2420 is high performance multimedia application processor based on the enhanced OMAP™ 2.0 Architecture. The core runs at 1.05V and 1.3V nominal while the interface is specified at 1.8V nominal. MCU core is ARM 1136JF-S™ DSP core TI 55X is inside ARM 7 base IVA module is Image and Video Accelerator There are internal ROM/RAM and external memory controller N93 is using General Purpose Memory Controller for MuxOneNAND flash memory, SDRAM Controller for DDR memory Display SubSystem has video out block which can convert video data to Composite video signal DMA controller transfers data between block to block without SW operation Menelaus Menelaus EM ASIC includes following functional blocks: OMAP2420 Core supply generation OMAP2420 I/O supply generation OMAP2420 PLL block supply generation DDR/NAND Memory Core and I/O supply generation Reference voltage generation for TV-OUT block in OMAP2420 TV-OUT buffer (BUFFY) and TMP105 Temperature Sensor supply generation Level shifter and regulator for miniSD card |
03-05-2008, 08:35 | #4 (permalink) |
Member: 138020 Status: Offline Thanks Meter: 87 | Power-up Sequence Clock Distribution A 38.4MHz VCTCXO is used as system clock. The 38.4MHz system clock is fed unbuffered to RF ASICs. After buffering in PIHI, the 38.4MHz differential clock is then fed to RAP3GS/RAPS. The 38.4MHz clock coming from VCTCXO is buffered again for BT. RAP3GS/RAPS slices 19.2MHz for OMAP2420. In SLEEP mode the VCTCXO is off. Vilma generates low frequency sleep clock signal (32.768 kHz) that is fed to Betty, RAP3GS/RAPS and OMAP. Betty uses external 2.4MHz SMPS-clock as long as external SleepX -signal is HIGH-state. Otherwise 2.4MHz internal RC-oscillator is used to generate clocks inside Betty. |
03-05-2008, 11:26 | #5 (permalink) |
Member: 138020 Status: Offline Thanks Meter: 87 | Main Camera Sensor: 1/3.2-inch 3.2M pixels Lens: Auto Focus, Optical Zoom up to 3x Electrical Interfaces Main Camera is connected to OMAP2420 Data Transfer: CCP (Sub-LVDS, up to 208MHz) Control: I2C (1.8V, 100kHz) Power Supply: Three 3.0V discrete regulators (AVDD, DVDD, LVDD) and APE_VIO from Menelaus Clock: FCLK (19.2MHz) from OMAP2420 Others: RESET and PWDN |
03-05-2008, 11:30 | #6 (permalink) |
Member: 138020 Status: Offline Thanks Meter: 87 | Sub Camera Sensor: 1/7-inch CIF CMOS Lens: Fixed Focus Electrical Interfaces Sub Camera is connected to Main Camera (NOT to OMAP2420) Data Transfer: Parallel 9 bit Control: I2C with Enable (2.9V, 560kHz) Power Supply: CIFVDD (2.9V) from Main Camera Clock: CIFMCK (9MHz) from Main Camera |
03-05-2008, 11:32 | #7 (permalink) |
Member: 138020 Status: Offline Thanks Meter: 87 | Flash & Indicator LED Flash LEDs and Indicator LED is mounted on the UI PWB. Flash LED driver circuit and Indicator control circuit are located on Engine PWB. Engine PWB and UI PWB are connected by 50-pin board-to-board connector . - 2 signals for Flash LED current - 2 signals for Indicator LED current |
03-05-2008, 11:34 | #8 (permalink) |
Member: 138020 Status: Offline Thanks Meter: 87 | Display Module Main display Active matrix TFT/Wide-viewing LCD (240x320(QVGA), 256k colors) MeSSI-16 with 8 bit bus 4 white LED backlight Transflective Normally black color at power off ------------------- Sub display CSTN (Color STN) LCD (128x36, 64k colors) LoSSI 1 white LED backlight Transmissive Normally black color at power off |
03-05-2008, 11:36 | #9 (permalink) |
Member: 138020 Status: Offline Thanks Meter: 87 | Display and Keyboard Backlight N93 has one Led Driver (SMPS) that is used to drive both Main/Sub display and keyboard LED’s Main Display LED’s (4pcs), Sub Display LED (1pc) and keyboard LEDs (4pcs x3) are connected in series In typical use case keyboard LEDs are turned ON only in dark ambient lighting conditions Maximum voltage level for keyboard & display LEDs is 18V (over the whole LED chain), typical value is 15V. LED currents for display and keyboard variates a lot due to SW control. |
03-05-2008, 11:37 | #10 (permalink) |
Member: 138020 Status: Offline Thanks Meter: 87 | Sensors Ambient light sensor(ALS) Information of ambient lighting is used to control backlights of the phone Keypad lighting is only switched on, when environment is dark / dim Display backlights are dimmed, when environment is dark / dim Data is sampled by AD converter located in Vilma. Rotation sensor Rotation sensor locates on Flip flexi PWB and a mechanical switch is used for it. Data is corrected by OMAP2420. Flip open/close sensor Flip open/close sensor is located on UI flexi PWB and MR (Magneto Resistive) sensor is used for. MR sensor is bit more sensitive to the magnetic field compared to hall sensor. Magnetic field detection is different from hall sensor. Regular magnets designed for hall sensor usage might not work correctly with MR sensor. MR sensor is omnipolar. Polarity can be either way, but field direction has to be corrected by OMAP. |
03-05-2008, 14:57 | #11 (permalink) |
Member: 138020 Status: Offline Thanks Meter: 87 | Audio Block Diagram RAP3GS/RAPS & Vilma form the audio codec Vilma provides interface for the transducers and the accessory connector N93 used transducers: Earpiece IHF Microphone : 2 x digital Audio modes are: Hand portable mode Headset mode Hands free mode |
03-05-2008, 15:00 | #12 (permalink) |
Member: 138020 Status: Offline Thanks Meter: 87 | Audio Modes (Hand portable mode) RAP3GS/RAPS’s AuxMicDat used for internal digital microphones. Left side (key side) microphone is used as telephony mode, and both digital microphones are used as stereo recording microphones for camcorder mode. The PDM output is transferred from RAP3GS/RAPS to VILMA in EarDaL line EARP and EARN outputs are led differentially to earpiece |
03-05-2008, 15:02 | #13 (permalink) |
Member: 138020 Status: Offline Thanks Meter: 87 | Audio Modes (Headset mode) Vilma differential microphone inputs MIC2P and MIC2N used for accessory audio microphone Vilma transmits PDM signal via MicData to RAP 3GS/RAPS for further processing ACI line used for accessory detection The mono/stereo PDM output is transferred from RAP3GS/RAPS to Vilma in EarDaL and (in stereo case) EarDaR line(s) XEARR and XEARL outputs are led differentially to headset |
03-05-2008, 15:04 | #14 (permalink) |
Member: 138020 Status: Offline Thanks Meter: 87 | Audio Modes (Hands free mode) RAP3GS/RAPS’s AuxMicDat used for internal digital microphones. Left side (key side) microphone is used in handsfree telephony mode. The PWM output for the internal handsfree speaker is led from RAP3GS/RAPS to Vilma via PMARP and PMARN lines. Digital amplifier output is led differentially via HFSpP and HFSpN lines to IHF speaker |
03-05-2008, 15:09 | #15 (permalink) |
Member: 138020 Status: Offline Thanks Meter: 87 | TV-out Composite video only. No S-Video etc, higher quality. TV-out function is multiplexed on XEARN in Pop-PortTM . The ****og switch is used to switch each function. Buffy is a video amplifier IC. TV-out cable CA-64U is used to connect between phone and TV. |
i need password for My account i have all info ( RASKAL ) | flechazo | Twisterflasher | 2 | 04-08-2005 01:38 |
SAGMaster - new software. All info here | hackgsm.net | ARM9 BASED M62 / M62+ | 0 | 06-15-2004 19:41 |
[INFO] All p2k language packs code | Treviño | Motorola P2k | 2 | 08-05-2003 06:20 |
Today I've found good Xak's site , all info for free | Crew | GSM Mobile Links | 2 | 01-17-2003 19:59 |
THNX DENNY .. but PLZ ALL HELP ME ALL INFO HERE. | makona | Alcatel & TCL Old Models | 3 | 03-26-2000 09:47 |
