10-24-2008, 09:15 | #1 (permalink) |
Freak Poster Join Date: Mar 2006 Location: in front of my customer Age: 45
Member: 244407 Status: Offline Thanks Meter: 56 | HELP nokia 6500c fake charging only!!! if anybody have a fake charging solution please share to us, maybe i'm not the only one who encounter this problem but many.. The problem is it indicates chagring but not totally charge the battery it cannot full the battery, i check also flex inside and it looks okey, i also chage the battery but still cannot fully charge the battery... if somebady got this charging ways or picture i would be thankful for you. BR, Richello Baring |
10-25-2008, 08:16 | #2 (permalink) |
Member: 244407 Status: Offline Thanks Meter: 56 | Problem Solved! Okey i just repaired the charging problem a while ago and it's working fine now... i just made a jumper with it after i was able to trace the possitive (+) ways from USB to flex connector to main board. and now i works fine and it can totally stored energy to the battery! but sorry i do not have image to upload becase i don't have a camera. |
12-01-2008, 21:34 | #6 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Estonia Age: 37
Member: 154612 Status: Offline Thanks Meter: 824 | Ok, understandable, u can try this remove d2400 ( i think u have layout?) and make jumper between V2000 and C2006 ok i made little pic too.... BR Janar |
The Following 13 Users Say Thank You to janar_jk For This Useful Post: |
05-02-2009, 06:51 | #14 (permalink) |
Member: 244407 Status: Offline Thanks Meter: 56 | charging ways as alternative solution. This is the image i share to all of you which i manage to troubleshoot fake charging... press thanks button if you like it... |
The Following 11 Users Say Thank You to richello baring For This Useful Post: |
05-27-2009, 20:29 | #15 (permalink) |
Freak Poster Join Date: Apr 2002 Location: BiH, Srebrenik Age: 53
Member: 10960 Status: Offline Thanks Meter: 5 | problem solved Ribon is bad. Measured resistance betwen pin1 usb and pins123 b2b connector is about 90 ohm! Patch it with thin wire, form USB pin1 to b2b connector pins 1, 2, 3. At picture above, only yellow wire is enough. |
The Following User Says Thank You to bello For This Useful Post: |
Nokia 6500c fake charging.charging not save solution | mahbubalfa | Nokia Hardware & Hardware Repair | 12 | 05-08-2011 10:47 |
Nokia N96 fake charging.charging not save solution | mahbubalfa | Nokia Hardware & Hardware Repair | 4 | 11-15-2010 17:09 |
please help nokia 6300 fake charge | sira | Nokia Hardware & Hardware Repair | 0 | 03-22-2010 14:46 |
6500c fake charging......... | dawah telecom | Nokia Hardware & Hardware Repair | 9 | 06-14-2009 04:19 |
Nokia 6085 fake charging | arturo011 | Nokia Hardware & Hardware Repair | 3 | 09-15-2008 10:24 |
