05-20-2011, 16:42 | #4 (permalink) | |
No Life Poster Join Date: Dec 2008 Location: Apple pocket Age: 32
Member: 936020 Status: Offline Sonork: 100.1611462 Thanks Meter: 2,771 | Quote:
brother a few days ago i received 1 nokia 5233 handset which problem was full battary connector ways destroyed.then i find out positive(v+) and negetive connection.but set not on.just feel viveration when try to open.then i make jumper of bsi connection and now phone still working as well good condition.to see my successfull report cheak this link here | |
05-20-2011, 17:36 | #5 (permalink) | |
Insane Poster Join Date: May 2011
Member: 1577624 Status: Offline Thanks Meter: 24 | Quote:
see this log........... Number of Image Files: 4 Processing Image File : RM-596_014.002_79.92_prd.core.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 13000000Hz Message Reading Speed : 98000Hz Number of Blocks : 549 Entry Point: 0x01E9 Page Format : -1 MAX PAGE : 0x00040000 Processing Image File : RM-596_014.002_00.01_79.92_prd.rofs3.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 13000000Hz Message Reading Speed : 98000Hz Number of Blocks : 2 Entry Point: 0x00EE Page Format : -1 MAX PAGE : 0x00000E00 Processing Image File : RM-596_014.002_10.01_Hebrew_79.92_prd.rofs2.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 13000000Hz Message Reading Speed : 98000Hz Number of Blocks : 149 Entry Point: 0x00EE Page Format : -1 MAX PAGE : 0x00040000 Processing Image File : RM-596_014.002_U01.01_79.92_prd.uda.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 13000000Hz Message Reading Speed : 98000Hz Number of Blocks : 228 Entry Point: 0x00EE Page Format : -1 MAX PAGE : 0x00040000 AUTO SELECTED DEAD USB FLASHING... If Flashing DOES NOT Start in 5 Seconds, Then Perform Steps 1, 2, 3 and 4... 1. Remove USB and Battery... 2. Insert USB. 3. Insert Battery. (Some phones boot automatically) 4. Please Power on phone shortly.. AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 BootRom Verified! BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000003 ID DWORD 1 : 00000226 ID DWORD 2 : 00010007 ID DWORD 3 : 600C1921 ID DWORD 4 : 02031104 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000C35 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000C30 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 17500113 ID DWORD 1 : E9A40344 ID DWORD 2 : 13299106 ID DWORD 3 : B05D427B ID DWORD 4 : 8C1AF25E 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 91 6F 75 21 7F 32 08 12 48 B1 5C 38 DF C8 E8 1B 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : E693EF0D CRC 1 : AC22615B START FLASHING RawLoaderExtract: Processing RM-596_014.002_79.92_prd.core.fpsx CMT Secondary Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\BB5_USBLoaders\RAPUv11_2n d.fg Secondary Loader Sent... MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 06 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> not detected Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> not detected Extended/Fixed ID : 0000 Revision ID : 0000 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 01 Manufacturer Code : 0000 -> SPANSION Device ID : 0001 -> not used Extended/Fixed ID : 0000 Revision ID : 0000 5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MuxOneNAND 03 Device Index : 00 Manufacturer Code : 00EC -> Device ID : 0050 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0031 6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5 Block Length : 09 BB ASIC Index : CMT 00 Data : SearchForBootstrap_DCT5 : No Error - 0 (0x00) Flash Descriptor Manufacturer Code : 00EC Device ID : 0050 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 20000000 (512 MB) VPP Info : 0000 Erase10s : 1E Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 CMT Algorithm Loader:C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\BB5_USBLoaders\RAPUv11_XS R17_alg.fg Algorithm Loader Sent... FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) FUR control Ok START READING RPL DATA IMEI: 352684047453522 Reading : NPC... OK! Reading : CCC... OK! Reading : HWC... OK! Reading : R&D... OK! RPL Backup was Successful... Plain RPL saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\352684047453522\3526840474535 22_73127.rpl Pabub KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 00 CMT PAPUBKEYS HASH: D172C32473AE199B213465ABB3853246F9631231 ImagePath: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-596\ ImadeFilename: RM-596_014.002_79.92_prd.core.fpsx Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01) Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only) Certificate 1 Name : NPC ASIC Index : CMT 0 Certificate 2 Name : CCC ASIC Index : CMT 0 Certificate 3 Name : HWC ASIC Index : CMT 0 Certificate 4 Name : R&D ASIC Index : CMT 0 STORE_CERTIFICATE_REQUEST_BB5 : 61 04 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 D3 STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5... Partition Info Partition Blocks : 1 1 PARTITION_INFO_BB5 BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Partition Version : 00020000 Spare : FFFFFFFF Num Partitions : 00000004 Partition 1 ID : 00000003 COPIEDOS Attribute : 00000002 RO Start Address : 00140000 Size : 02E60000 Partition 2 ID : 00000004 DEMANDONOS Attribute : 00000002 RO Start Address : 02FA0000 Size : 0B9E0000 Partition 3 ID : 00000008 FILESYSTEM Attribute : 00000001 RW Start Address : 0EA00000 Size : 10600000 Partition 4 ID : 0000000A PMM Attribute : 00000001 RW Start Address : 1F000000 Size : 00400000 PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000020000FFFFFFFF00000004000000030000 00020014000002E60000000000040000000202FA00000B9E00 0000000008000000010EA00000106000000000000A00000001 1F000000004000003E PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5 : No Error - 0 (0x00) StartErase_DCT5... BlockLength : 0x4F (79) ERASE Blocks : 0x02 (2) 0 ERASE_AREA_BB5 0x12 Block Length : 0x1B (27) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 00040000-0007FFFF 1 : 000C0000-008BFFFF 2 : 00DC0000-0E97FFFF 1 FORMAT_PARTITION_BB5 0x19 Block Length : 0x2F (47) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Format Info ID : 0x03000000 Format Info : 000000000000000A0000000000000002000000640018000000 000002000000010000000000000000 ERASE_REQUEST_BB5 : 5003120B000300000400000007FFFF120B000300000C000000 8BFFFF120B00030000DC00000E97FFFF7F ERASE_REQUEST_BB5 : 5001192F00030000000003000000000000000A000000000000 00020000006400180000000000020000000100000000000000 0025 Successfully erased.. Total blocks to write : 549 >> CMT Rootkey Hash CERT : ADA >> CMT Rootkey Hash CERT : KEYS >> CMT Rootkey Hash CERT : PRIMAPP >> CMT Rootkey Hash CERT : RAP3NAND >> CMT Rootkey Hash CERT : SOS+PMML >> CMT Rootkey Hash CERT : PASUBTOC >> CMT Rootkey Hash CERT : PAPUBKEYS >> CMT Rootkey Hash CERT : GENIO_INIT >> CMT Rootkey Hash CERT : SOS*UPDAPP >> CMT Rootkey Hash CERT : SOS*DSP0 >> CMT Rootkey Hash CERT : LDSP >> CMT Rootkey Hash CERT : SOS*ISASW >> CMT Rootkey Hash CERT : SOS+CORE >> CMT Rootkey Hash CERT : SOS+ROFS1 ImagePath: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-596\ ImadeFilename: RM-596_014.002_00.01_79.92_prd.rofs3.fpsx StartErase_DCT5... BlockLength : 0x0E (14) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 0DA80000-0E97FFFF ERASE_REQUEST_BB5 : 5001120B0003000DA800000E97FFFF86 Successfully erased.. Total blocks to write : 2 >> CMT Rootkey Hash CERT : SOS+ROFS3 ImagePath: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-596\ ImadeFilename: RM-596_014.002_10.01_Hebrew_79.92_prd.rofs2.fpsx StartErase_DCT5... BlockLength : 0x0E (14) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 09F40000-0DA7FFFF ERASE_REQUEST_BB5 : 5001120B00030009F400000DA7FFFF2F Successfully erased.. Total blocks to write : 149 >> CMT Rootkey Hash CERT : SOS+ROFS2 ImagePath: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-596\ ImadeFilename: RM-596_014.002_U01.01_79.92_prd.uda.fpsx StartErase_DCT5... BlockLength : 0x0E (14) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 0EA00000-1EFFFFFF ERASE_REQUEST_BB5 : 5001120B0003000EA000001EFFFFFF15 Successfully erased.. Total blocks to write : 228 ContinueFlash_DCT5 Complete Continue Flash Complete : : No Error - 0 (0x00) Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000001 Additional Bad : 00000001 Correctable ECC : 00000000 FlashInfo.RestartMode : 1 Flashing Done... Total Flashing Time (Erase + Flashing) : 00:00:31 (Booting time is NOT Included) Waiting for Phone to Start-Up..(Max 100 seconds) If Windows is Installing Drivers... Phone Polling MIGHT Exit Automatically. Elapsed Time: 5 Seconds... Elapsed Time: 10 Seconds... Elapsed Time: 15 Seconds... Elapsed Time: 20 Seconds... Elapsed Time: 25 Seconds... Elapsed Time: 30 Seconds... Elapsed Time: 35 Seconds... Elapsed Time: 40 Seconds... Elapsed Time: 45 Seconds... Elapsed Time: 50 Seconds... Elapsed Time: 55 Seconds... Elapsed Time: 60 Seconds... Elapsed Time: 65 Seconds... Elapsed Time: 70 Seconds... Elapsed Time: 75 Seconds... Elapsed Time: 80 Seconds... Elapsed Time: 85 Seconds... Elapsed Time: 90 Seconds... Elapsed Time: 95 Seconds... Elapsed Time: 100 Seconds... WARNING: Phone is not in the Required Mode... Disconnect the Phone and Power it Up Manually. | |
need ericsson 88 cable | migdamas | Old Ericsson Phones & Sony Phones | 2 | 03-24-2017 16:24 |
need eeprom photo???? | mobileinfo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-26-1999 11:35 |
