01-27-2014, 03:07 | #1 (permalink) |
Freak Poster Join Date: Jun 2010 Location: ANGUL,ODISHA,INDIA
Member: 1320421 Status: Offline Thanks Meter: 8 | Need nokia 2690 contact service & DCC File Mismatched! solutions SIMLOCK TABLE : 19:35:08 : Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open 19:35:08 : Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open 19:35:08 : Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open 19:35:08 : Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open 19:35:08 : Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open 19:35:08 : Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open 19:35:08 : Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open 19:35:08 : SIMLOCK STATE : Not Locked 19:35:08 : 19:35:08 : SIMLOCK_TYPE : PA_SL3 (15-digit NCK) 19:35:08 : SIMLOCK_TEST : PASSED 19:35:09 : SECURITY_TEST : FAILED 19:35:09 : > Try SX4 "PM AUTH" 19:35:09 : > Then Write PM 1 and 309 19:35:09 : SECURITY_CODE : 12345 19:35:10 : PHONE_MODE : TEST 19:35:11 : 19:35:11 : ================================================ 19:35:11 : Dynamic Camera Configuration 19:35:11 : ================================================ 19:35:11 : DCC ID : NIMMIIIIRRFF00000000 19:35:11 : DCC Ver: XXXXXX 19:35:11 : 19:35:11 : ERROR: DCC File Mismatched! 19:35:11 : 19:35:11 : Required DCC File:NIMMIIIIRRFF00000000 19:35:11 : Write the correct DCC to Fix the Problem 19:35:21 : 19:35:22 : 19:35:22 : FACTORY SET TO : Full Factory Set 19:35:22 : OK 19:35:22 : FACTORY SET TO : User Data 19:35:22 : OK 19:35:22 : FACTORY SET TO : Leave Factory 19:35:24 : FAILED 19:35:24 : FACTORY SET TO : Service Center 19:35:26 : FAILED 19:35:26 : FACTORY SET TO : Software Upgrade 19:35:27 : OK 19:35:27 : FACTORY SET TO : Production Tune 19:35:31 : OK |
01-27-2014, 19:51 | #3 (permalink) |
Moderator Join Date: Jul 2006 Location: Midnapore,West-Bengal,India
Member: 322206 Status: Offline Sonork: 100.1594813/.:SARCAR:. Thanks Meter: 1,350 | yeap , make sx4 auth & try write pm 1,309 for security issue . and try write appropriate dcc file if still same then try to replace camera module then check . |
