Old 09-14-2010, 22:42   #1 (permalink)
Member: 1070908
Sonork: bogha
Thanks Meter: 29
nokia 1202 whit screen
this mx key log
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010)
ASIC ID: 0x2293 [UPPCosto ver:
2.0]
SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8
Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168
FlashID0: 00EC 2606 [Samsung K8S3215ETF,32 Mbits] page size: 64 K type: NOR area:
01000000-013FFFFF
FlashID1:
0000 0001 [unused/removed]
ExtBUSC:
AD7E B61A 2310 0340 C605 E401 20A2 6514
Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0
Performing Flash Authentication ...OK
UEM ID:
0073EFBAA3BDA66
ASIC type:
11
UEM Imei:
35825103062153
Phone Type:
RH-112
SW Version:
V 04.03 29-06-09 RH-112 (c) Nokia
Imei plain:
35825103062153-3
Product Code:
0562683
Cellular System:
GSM
ASIC ID: 0x2293, type:
11
Ppm Id:
IC
Language Pack:
- not available.
Imei net:
35825103062153
Version:
SIMLOCK SERVER
Provider: ALL Operator, Country:
Counter: 0/3, 0/10
CONFIG_DATA:
0010100000000000
PROFILE_BITS:
000000000003000B
BLOCK 1:
1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 2:
BLOCK 3:
BLOCK 4:
BLOCK 5:
BLOCK 6:
BLOCK 7:
Invalid UEM Data, No RPL backup will be made for this phone.
please help thanx in advance
and this is flash log
ASIC ID: 0x2293 [UPPCosto ver: 2.0]
FlashID0: 00EC 2606 [Samsung K8S3215ETF,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF
FlashID1: 0000 0001 [unused/removed]
ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514
UEM ID: 0073EFBAA3BDA66
ASIC type: 11
UEM Imei: 35825103062153
Processing file: rh112_004.030 as MCU
[DCT4,DCT4 ALGORITHM] size: 2.29 MB
Supported Ids: 2293
UEM ID: 0073EFBA:2984DA60
Area [01000000-0100FFFF] erased in 0.422 s
Area [01010000-013AFFFF] erased in 22.671 s
Area [013B0000-013EFFFF] erased in 1.640 s
Area [017C0000-017EFFFF] erased in 0.156 s
Area [01FC0000-01FEFFFF] erased in 0.172 s
Flash programming ...
Programming completed in 18.938 s
File Processed in 53.406 s
Processing file: rh1120_nai04.03ic as CNT
[DCT4,DCT4 ALGORITHM] size: 163.91 KB
Supported Ids: 2293
Area [01380000-013AFFFF] erased in 1.266 s
Programming completed in 1.468 s
Extracting Content Pack, File Server fake reply for CUI phone.
Content Pack extracted successfully in 0.172 s
File Processed in 20.672 s
Processing file: rh112_004.03ic as PPM
[DCT4,DCT4 ALGORITHM] size: 1.10 MB
Supported Ids: 2293
Area [01240000-0124FFFF] erased in 0.406 s
Area [01250000-0137FFFF] erased in 7.500 s
Programming completed in 9.187 s
File Processed in 28.703 s
Flashing completed in 2 min 22.438 s
Old 09-14-2010, 22:51   #2 (permalink)
vlada84's Avatar
Member: 250049
Sonork: 1589029
Thanks Meter: 63
You already posted problem here http://forum.gsmhosting.com/vbb/f550...5/#post6331295
And solution is CLEAR if you realy working repairing phones. Open phone and count parts from right to left....
Old 09-15-2010, 03:57   #3 (permalink)
ham_sang's Avatar
Member: 901472
Thanks Meter: 48
Originally Posted by KM Sariful View Post
bro change LCD ......................10000% ok
change lcd the right solution....
Ham_sang
The Following User Says Thank You to ham_sang For This Useful Post:
Old 09-15-2010, 05:58   #4 (permalink)
Member: 540345
Thanks Meter: 175
white dispjay dardware problum
check these lines
if break make jumper
The Following User Says Thank You to asifawan For This Useful Post:
Page generated in 0.18304 seconds with 9 queries
