09-14-2010, 22:42 | #1 (permalink) |
Freak Poster Join Date: Jul 2009 Location: nokia n82 Age: 38
Member: 1070908 Status: Offline Sonork: bogha Thanks Meter: 29 | nokia 1202 whit screen Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010) ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2606 [Samsung K8S3215ETF,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0073EFBAA3BDA66 ASIC type: 11 UEM Imei: 35825103062153 Phone Type: RH-112 SW Version: V 04.03 29-06-09 RH-112 (c) Nokia Imei plain: 35825103062153-3 Product Code: 0562683 Cellular System: GSM ASIC ID: 0x2293, type: 11 Ppm Id: IC Language Pack: - not available. Imei net: 35825103062153 Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 000000000003000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN Invalid UEM Data, No RPL backup will be made for this phone. please help thanx in advance and this is flash log Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010) ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2606 [Samsung K8S3215ETF,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0073EFBAA3BDA66 ASIC type: 11 UEM Imei: 35825103062153 Processing file: rh112_004.030 as MCU [DCT4,DCT4 ALGORITHM] size: 2.29 MB Supported Ids: 2293 ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2606 [Samsung K8S3215ETF,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0073EFBA:2984DA60 Area [01000000-0100FFFF] erased in 0.422 s Area [01010000-013AFFFF] erased in 22.671 s Area [013B0000-013EFFFF] erased in 1.640 s Area [017C0000-017EFFFF] erased in 0.156 s Area [01FC0000-01FEFFFF] erased in 0.172 s Flash programming ... Programming completed in 18.938 s File Processed in 53.406 s Processing file: rh1120_nai04.03ic as CNT [DCT4,DCT4 ALGORITHM] size: 163.91 KB Supported Ids: 2293 ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2606 [Samsung K8S3215ETF,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0073EFBA:2984DA60 Area [01380000-013AFFFF] erased in 1.266 s Flash programming ... Programming completed in 1.468 s Extracting Content Pack, File Server fake reply for CUI phone. Content Pack extracted successfully in 0.172 s File Processed in 20.672 s Processing file: rh112_004.03ic as PPM [DCT4,DCT4 ALGORITHM] size: 1.10 MB Supported Ids: 2293 ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2606 [Samsung K8S3215ETF,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0073EFBA:2984DA60 Area [01240000-0124FFFF] erased in 0.406 s Area [01250000-0137FFFF] erased in 7.500 s Flash programming ... Programming completed in 9.187 s File Processed in 28.703 s Flashing completed in 2 min 22.438 s |
09-14-2010, 22:51 | #2 (permalink) |
Freak Poster Join Date: Mar 2006 Location: Beograd, Srbija Age: 39
Member: 250049 Status: Offline Sonork: 1589029 Thanks Meter: 63 | You already posted problem here http://forum.gsmhosting.com/vbb/f550...5/#post6331295 And solution is CLEAR if you realy working repairing phones. Open phone and count parts from right to left.... |
