06-02-2006, 09:58 | #2 (permalink) |
No Life Poster Join Date: Nov 2001 Location: England Age: 41
Member: 7653 Status: Offline Thanks Meter: 823 | u must change the static discharge filter (or bridge it). it is locate very near the sim card holder and is a small square that looks metallic (some call it the glass IC). you can take from any DCT4 nokia, or search for bridging method used in 8310. for best results, you can buy original new component in www.i-phone.org |
06-02-2006, 10:01 | #3 (permalink) | |
No Life Poster Join Date: Feb 2003 Location: In My Pub
Member: 307549 Status: Offline Thanks Meter: 188 | Quote:
06-02-2006, 10:13 | #4 (permalink) | |
No Life Poster Join Date: Sep 2005 Location: Uttaranchal Age: 35
Member: 181696 Status: Offline Sonork: 100.107830 Thanks Meter: 5,406 | Quote:
1100 insert sim card problam.... see this image | |
The Following 3 Users Say Thank You to ..::ArchitRaj::.. For This Useful Post: |
06-02-2006, 10:19 | #5 (permalink) | |
Freak Poster Join Date: Jul 2003 Location: NIGERIA, HEART OF AFRICA
Member: 34594 Status: Offline Thanks Meter: 26 | Quote:
Check d battery contact. if the battery contact pins is not even & allign, it causes insert sim problem in 1100 & 2300 nokia. so use a tweezer to adjust & re-allign the battery contact pins. i think it should solve the problem. BR | |
06-02-2006, 12:11 | #6 (permalink) |
Member: 7653 Status: Offline Thanks Meter: 823 | i do not reball personally, i will only work with new pre balled IC. i have reballed a few COBBA IC just for fun in the past, it is not an easy job |
06-02-2006, 12:13 | #7 (permalink) |
Member: 7653 Status: Offline Thanks Meter: 823 | however, with a very steady hand, you can lift an IC and leave enough solder on the board to attach a new IC. i have managed that with one t630 charging filter, before we got the parts in stock. if one ball is slightly missing, you can touch the spot up with your fine tip soldering iron and small amout of tin |
06-02-2006, 12:13 | #8 (permalink) |
No Life Poster Join Date: Jan 2006 Location: inside emmc ufs Age: 19
Member: 221603 Status: Offline Sonork: 100.1581270 Thanks Meter: 6,395 | chek the center pin of batery terminal... if it not sold well or broken or not making contact with the baterry.... this can be the only reason... best of luck... |
06-03-2006, 04:35 | #10 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | step 1. sim tray- clean all 6 terminals, if not solve. step 2. battery connecter- allign it properly with a good twiser, if not solve. step 3. crystal ic- check ic top right near sim tray & follow the instruction as sir architraj has given in his post reply, 100% solution for it, dear . |
06-03-2006, 13:51 | #12 (permalink) | |
No Life Poster Join Date: Sep 2005 Location: Australia
Member: 177568 Status: Offline Thanks Meter: 146 | Have you tried a different battery? Sometimes, it's just a leakage in the battery. It works for me in Nokia 1100 and 7370. Quote:
12-11-2014, 09:15 | #14 (permalink) |
Junior Member Join Date: Mar 2011 Location: Shahabad Markanda
Member: 1544801 Status: Offline Sonork: [email protected] Thanks Meter: 0 | nokia 1100 insert sim solution. just change battery ur problem solved. i tried many times |
Nokia 1100 insert sim problem | parthiban_ctr | Nokia Hardware & Hardware Repair | 0 | 02-26-2010 06:12 |
nokia 1100 insert sim | nkakanou | Nokia Hardware & Hardware Repair | 1 | 02-01-2006 00:55 |
Nokia 1100 insert sim card | hitibiti | Nokia Hardware & Hardware Repair | 15 | 09-07-2005 17:43 |
needs help for nokia 1100 insert sim card pls help me some one | Javajohn | Nokia Hardware & Hardware Repair | 2 | 07-09-2005 12:21 |
Nokia 1100 insert sim card | KRIZA | Nokia Hardware & Hardware Repair | 8 | 09-16-2004 07:36 |
