Old 04-02-2009, 13:34   #1 (permalink)
Rizwan ch08's Avatar
Member: 637860
Sonork: 100.1605309
Thanks Meter: 996
Arrow Nokia 1202 local mode ..???????
any body help me nokia 1202 local mode ?????.plz urgent solution...................
Old 04-02-2009, 13:41   #2 (permalink)
sunnyarora's Avatar
Member: 483406
Thanks Meter: 180
first remove this resistance if not ok then change with 1110 1600
The Following 2 Users Say Thank You to sunnyarora For This Useful Post:
Old 04-02-2009, 13:54   #3 (permalink)
Registered User
Member: 407063
Thanks Meter: 2,133
The Following 2 Users Say Thank You to naeem_skg786 For This Useful Post:
Old 04-03-2009, 06:50   #4 (permalink)
murthyy's Avatar
Member: 265133
Thanks Meter: 285
Originally Posted by sunnyarora View Post
Attachment 193944
he has asked for 1202 local mode and u have provided 1200
Old 04-03-2009, 07:30   #5 (permalink)
s.s.s.s.'s Avatar
Member: 988641
Sonork: sanjay chaudhary
Thanks Meter: 342
bro,
check charging connector first
The Following User Says Thank You to s.s.s.s. For This Useful Post:
Old 04-18-2009, 12:50   #6 (permalink)
habibuddin's Avatar
Member: 441231
Thanks Meter: 206
1202 local mode
Have any motherboard picture? so that upload the pictuer. i will give
the solution that is tested by me 100%.
B.R.
The Following User Says Thank You to habibuddin For This Useful Post:
Old 04-18-2009, 12:56   #7 (permalink)
habibuddin's Avatar
Member: 441231
Thanks Meter: 206
1202 local mode?
Remove the 4pin resistor that is uper the power ic.
I have tested few minutes ago.
B.R.
The Following 3 Users Say Thank You to habibuddin For This Useful Post:
Old 04-18-2009, 13:41   #8 (permalink)
panipat's Avatar
Member: 995130
Sonork: SAMRAT
Thanks Meter: 34
change this charging jack ok
The Following 2 Users Say Thank You to panipat For This Useful Post:
Old 04-19-2009, 06:33   #9 (permalink)
habibuddin's Avatar
Member: 441231
Thanks Meter: 206
1202 local mode
I changed charging jack but problem not solved. then 'REMOVE' 4 PIN RESISTOR ( upper the power ic ) and 100% solved the problem. anyway thanks for ur good comment.
B.R.
The Following 2 Users Say Thank You to habibuddin For This Useful Post:
Old 04-20-2009, 11:00   #10 (permalink)
Member: 1013706
Sonork: if
Thanks Meter: 2
ok...try this .. its useful.. i try already
The Following 2 Users Say Thank You to atan9667 For This Useful Post:
Old 04-20-2009, 11:05   #11 (permalink)
gsmshare's Avatar
Member: 429569
Thanks Meter: 1,543
bro try this hope 100% work
http://www.usaupload.net/d/xkl9nvlwyts
regards
gsmshare
The Following 4 Users Say Thank You to gsmshare For This Useful Post:
Old 05-04-2009, 06:13   #12 (permalink)
habibuddin's Avatar
Member: 441231
Thanks Meter: 206
And also check this page-http://forum.gsmhosting.com/vbb/show...62#post4433162
Old 05-04-2009, 06:34   #13 (permalink)
azez.sd's Avatar
Member: 735523
Sonork: 100.1591830
Thanks Meter: 262
goood woork guys .........
The Following 2 Users Say Thank You to azez.sd For This Useful Post:
Old 09-17-2010, 18:32   #14 (permalink)
Member: 1237011
Exclamation
ThankSSSSSSSSSSSSSSSSSSS
The Following User Says Thank You to eoky2010 For This Useful Post:
Old 09-20-2010, 16:07   #15 (permalink)
Member: 1169642
Sonork: 1587581
Thanks Meter: 234
Free File Hosting - USAupload.net
regards
gsmshare
thx.lot..............................
The Following User Says Thank You to GSM SOLUTION. For This Useful Post:
nokia 1661 local mode and test mode solved venusmobilecare Nokia Hardware & Hardware Repair 25 07-13-2011 16:30
1202 local mode plz help GSM_DREAMS Nokia Hardware & Hardware Repair 7 10-21-2009 15:54
1202 local mode real solution wanted ayubalikhan Nokia Hardware & Hardware Repair 4 09-04-2009 11:52
Nokia 6070 local mode and test mode help me ansari123 Nokia Hardware & Hardware Repair 5 07-05-2009 16:11
Nokia 1202 local mode Rizwan ch08 Nokia Hardware & Hardware Repair 1 06-12-2009 14:54
Page generated in 0.30752 seconds with 10 queries
