04-16-2010, 13:27 | #1 (permalink) |
Insane Poster Join Date: Nov 2009 Location: belgium
Member: 1169319 Status: Offline Thanks Meter: 8 | nokia 1661 contact service solution by mxkey sp data is crupped. any solution by mxkey or hwk.urgenthelp me. |
The Following 3 Users Say Thank You to nangia khan For This Useful Post: |
04-16-2010, 13:48 | #3 (permalink) | |
Freak Poster Join Date: Jan 2007 Location: Phillipines
Member: 437090 Status: Offline Thanks Meter: 131 | Quote:
if error occurs during unlock process... flashphone with original firmware and unlock again using mxkey dct4plus real unlock... problem will be solved! | |
The Following User Says Thank You to macoy0916 For This Useful Post: |
04-17-2010, 05:46 | #5 (permalink) |
Registered User Join Date: Apr 2008 Location: sadiqsajan
Member: 759011 Status: Offline Sonork: 164643 (server.sonork.com Thanks Meter: 152 | i try to unlock? 1661 i try to unlock but problam not selove? can u help me................................ |
The Following User Says Thank You to sadiq123 For This Useful Post: |
05-07-2010, 21:07 | #6 (permalink) |
Crazy Poster Join Date: Jun 2008 Location: INDIA(kolkata)
Member: 787026 Status: Offline Thanks Meter: 7 | Imei net: 35523303897601 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 0000000000000000 PROFILE_BITS: 0000000000030000 SIMLOCK_DATA corrupted! Calculating SIMLOCK RPL using security server ... SERVER->Served by MXKEY - BLADE X at host1, agent version 1.0 revision 1.6 Rpl backup saved to "C:\mobileEx\3.4\data\backup\RH-122_35523303897601_SIM.RPL" Updating SIMLOCK ...OK Reading Simlock info ... Imei net: 35523303897601 Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 000000000003000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN Phone Type: RH-122 bus chek info Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010) ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2254 [Samsung ] page size: 64 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00A76BD1A3BDA66 ASIC type: 11 UEM Imei: 35523303897601 Flash Imei: 35523303897601 MasterCode: 6341172130 RPL saved to "C:\mobileEx\3.4\data\backup\35523303897601_12 7325 5121_BACK.rpl" Phone Type: RH-122 SW Version: V 04.30 06-07-09 RH-122 (c) Nokia Imei plain: 35523303897601-3 Product Code: 0575936 Cellular System: GSM ASIC ID: 0x2293, type: 0 Ppm Id: AB Language Pack: - not available. Failed to read SP data scan info SW Version: V 04.30 06-07-09 RH-122 (c) Nokia Imei plain: 35523303897601-3 Product Code: 0575936 Cellular System: GSM ASIC ID: 0x2293, type: 11 Ppm Id: AB Language Pack: - not available. Imei net: 35523303897601 Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 000000000003000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN Total time to process is 2 min 59.718 s Version Info: RFIC version: 0700 DSP version: ICPR81_09w17_U LCD version: SDI:BOHAIv92 NT39121 PPM version: V 04.30 06-07-09 RH-122 (c) Nokia AB ADSP SW version: p V 04.30\n06-07-09\nRH-122\n(c) NMP\nab Product Info: Production serial number: IFQ867445 Product code: 0575936 Module code: 0204078 Basic production code: 0568809 Serial Numbers: IMEI plain: 355233038976013 IMEI spare to net: 3A 55 32 03 83 79 06 01 IMEI SV to net: 33 55 32 03 83 79 06 31 F0 Other Info: CS type : GSM/DCS1800 BSI: 4.5 KOhm Imei net: 35523303897601 Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 000000000003000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN after all cs not removed from my phone ,chek hardware pm245 but still cs any one help me....... |
The Following User Says Thank You to loknath1979 For This Useful Post: |
06-05-2010, 11:02 | #8 (permalink) | |
Junior Member Join Date: Aug 2009
Member: 1093822 Status: Offline Thanks Meter: 14 | Nokia 1661 Contact Service Solution 100% Tested Quote:
use directCom for set ufs to com port Run Nktoll and select unlock and click on Do Job Now ur 1661 contact service remove tested by me Happy to Help Anjali Mobile Kuchaman City [email protected] | |
The Following User Says Thank You to khiladi28 For This Useful Post: |
