Nokia 2600C Classic Automatic On & Keypad Problem... Hello Masters, Pls. help me in Nokia 2600C classic phone automatically getting swtiched on when I insert the battery. Keypad also not working. Even not being switched on after pressing the power on button. I have done the following things but not solved : 1. Changed the keypad ic twice. 2. Reballed the UEM. 3. Flashed it completely using the latest file version. 4. Resold the CPU i.e. heat up with AMTECH GEL. 5. Washed it thoroughly with thineer and IPA twice or thrice. What rest you can suggest me? Thanks in advance, Regards, amit123 |
did you teast with changing the internal keypad ??? |
result post here. |
due to complicated fualt. |
Thanks for ur reply. Yes, I changed the Keypad Flex with a good one but no joy for me so far. Can it be the RTC Problem? Thanks, Regards, amit123 |
