08-31-2008, 08:06 | #3 (permalink) |
No Life Poster Join Date: Oct 2005 Location: TITI 2002 SERVIS CELULAR PG/AL
Member: 193804 Status: Offline Sonork: 100.1684818 Thanks Meter: 1,693 | change the lcd or chek the scheme............... |
The Following User Says Thank You to genci titi 2002 For This Useful Post: |
06-05-2009, 13:04 | #8 (permalink) |
Junior Member Join Date: Jun 2009 Location: pakistan multan
Member: 1046052 Status: Offline Thanks Meter: 6 | hello brother its a hardware fault in light ic just check it and also check coil here is the full solution for nokia 1110, 2610, 1600, all same pcb have these problem here is the solution |
06-05-2009, 13:19 | #9 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Kathmandu, Nepal
Member: 260236 Status: Offline Sonork: 100.1641081 Thanks Meter: 135 | diagnose light faults in 1600, 2310, 2610 and so on No LCD or Keypad light follow procedure 1. check continuity, voltages, LED, LCD 2. voltages L2400 = 3.7/3.7 R2401 = 3.7/3.7 C2401= 3.7/0 v2401 ---> KDL = 2.18V @ lights off and 0v @ lights on ----------> Vflash1 = 2.18V ----------> EN = 2.18v @ lights on and 0v @ ligts off c2400 = 10v @ lights on v2400 3.6v->|- while lights on(+ve side) diagnosis no voltage @ c2400 ---> change N2400 no voltage @ v2400 check connection between c2400 to LCD#10 and LCD#9 to v2400 if OK check the LCD or v2400 (to check v2400/LCD simply short both pins of v2400 while lights on mode). post results |
2610 light problem plz helpe me | faheemkhan | Nokia Hardware & Hardware Repair | 2 | 07-19-2009 14:03 |
nokia 2610 light sultion | namat1 | Nokia Hardware & Hardware Repair | 1 | 06-21-2009 04:28 |
2610 light problem | tabarat1 | Nokia Hardware & Hardware Repair | 0 | 06-20-2009 10:33 |
NOKIA 2610 Lights Probelam | frfaisal | Nokia Hardware & Hardware Repair | 5 | 09-07-2008 21:33 |
