Old 08-16-2010, 07:53   #1 (permalink)
Member: 1317658
Sonork: prakash cellular service
Thanks Meter: 441
Question Nokia 2626 Contact Service Problem - Help..
Hi GSM Team
I Have Nokia 2626 Contact service Problem So i flash with Different-2 version but still same problem when i finish flash after that in normal mode i can access my mobile but when i put battery again contact service i think this is hardware problem .. so please help me anyone its really urgent
..:: X.Ram ::..
Old 08-16-2010, 08:12   #2 (permalink)
adonis1279's Avatar
Member: 164332
Thanks Meter: 40
mates try 2 write new pm then unlock after flashing the fone... if u have universalbox much better ihave the same problem yesterday it works for me
Old 08-16-2010, 11:47   #3 (permalink)
MIRPUR AJK's Avatar
Member: 725834
Thanks Meter: 921
try and chack this,,,,,,,,,,,,,
download link,,,,,,,
2626-charging.local,-.jpg - 4shared.com - photo sharing - download image
Old 08-16-2010, 11:51   #4 (permalink)
uandumobile's Avatar
Member: 1122200
Sonork: 100.1669761
Thanks Meter: 558
flash it pm edit good and ui setting and also try with mxkey hope problem slove 1st try in software then hardware
Old 08-16-2010, 12:11   #5 (permalink)
Member: 1241659
Thanks Meter: 165
Originally Posted by x.ram View Post
Hi GSM Team
..:: X.Ram ::..
if you have MX-KEy, then post bus scan log
Old 08-16-2010, 14:25   #6 (permalink)
kcs_reddy's Avatar
Member: 918795
Thanks Meter: 135
Hai.... X-ram
Use MX-Key...Update splock
100% U r problem solve,,,
Tested by me
Old 08-16-2010, 15:12   #7 (permalink)
ajmal_khan713's Avatar
Member: 894846
Sonork: ajmal
Thanks Meter: 111
post log here ................ may be hardware ..............
Old 08-18-2010, 07:02   #8 (permalink)
Member: 1317658
Thanks Meter: 441
Question
Hi Team
I Already try with and everything is fine software its getting on also in software but when i put battery again same problem and i allready try this
But still same problem any another solution
..:: X.Ram ::..
Old 08-18-2010, 07:58   #9 (permalink)
That'sme's Avatar
Member: 228871
Thanks Meter: 43
Hi Team
..:: X.Ram ::..
Rehot the UPP carefully Ur problem solved
Old 08-18-2010, 09:29   #10 (permalink)
Member: 233773
try to flash it with hwk or jaf
Old 04-09-2013, 23:06   #11 (permalink)
Member: 1892808
Sonork: ss
hello gsm team! i have 2626 nokia phone displaying contact service how can i solve this problem.
Old 04-09-2013, 23:15   #12 (permalink)
Member: 755974
Thanks Meter: 9
Send your phone to a service.
Old 04-10-2013, 06:32   #13 (permalink)
mahzra azra's Avatar
Member: 1722956
Sonork: mybestfriend.adeel
Thanks Meter: 305
Hi Team
..:: X.Ram ::..
if your mobile info is ok flashing is ok after that no solution then you only changed uem<power > ic 10000000%set will be ok.
trust me i made many sets ok. like 2626 1600 2310 6030 1200 1209 etc.
Old 09-07-2013, 15:49   #14 (permalink)
Member: 1985145
Thumbs up NOKIA 2626 COnatact Service
Replace PM file with HWK
1. Create PM file From any Running 2626
2. Place this file in contact service handset
ur Problem slolve 101 %
this is my Guaraanty
Old 09-09-2013, 19:30   #15 (permalink)
Member: 1222780
Thanks Meter: 2
First you try to software then remove bsi capacitor & if problem not solve then change uem with flash ic problem sovle
Page generated in 0.25917 seconds with 9 queries
