Old 08-14-2010, 13:31   #1 (permalink)
Registered User
Member: 1262367
Sonork: muhammedshafikulangaredat
Thanks Meter: 19
Nokia 2690 dead help me
Nokia 2690 charging ok but not power on i clean pcb but still problum help me .............
The Following 2 Users Say Thank You to shafi816 For This Useful Post:
Old 09-02-2010, 20:06   #2 (permalink)
Member: 1385069
Nokia 2690 also dead
I'm having the same problem. I'm 60, and can't understand all the jargon! Is there an easy explanation?
The Following User Says Thank You to sue.webb For This Useful Post:
Old 09-03-2010, 04:26   #3 (permalink)
amn32's Avatar
Member: 569925
Sonork: 100.1624057
Thanks Meter: 6,313
Check bsi line . May be its fault.
Old 09-03-2010, 05:08   #4 (permalink)
suraj9860607689's Avatar
Member: 787710
Sonork: not using
Thanks Meter: 771
bro chk voltage on on off key... its ok then flash
Old 09-03-2010, 08:26   #5 (permalink)
Member: 1385069
thanks but....
Thank you for the tips but I still don't understand. What is a bsi, and how do I check it? Do you mean the phone charger is faulty, and if so, how do I get a new one? Would it be easier if I just got a new phone? Is this a common fault? Could you write without text-speak, please.
Old 11-29-2010, 16:02   #6 (permalink)
Member: 780318
Thanks Meter: 13
2700
from on/off check track back side near keypad 2nd key ic down
Old 11-29-2010, 19:13   #7 (permalink)
mahbubalfa's Avatar
Member: 1003058
Sonork: 100.1589274/mahbubalfa
Thanks Meter: 26,433
Bro.try this solution.
The Following 5 Users Say Thank You to mahbubalfa For This Useful Post:
Old 12-01-2010, 20:06   #8 (permalink)
Member: 1442231
Thanks Meter: 3
thanks many many to solve
Old 03-29-2011, 04:54   #9 (permalink)
Member: 462076
Sonork: 100.1586314
Thanks Meter: 307
bro any solution for dead mobile
Old 03-29-2011, 05:45   #10 (permalink)
rekha1255's Avatar
Member: 333796
Sonork: 100.1587155
Thanks Meter: 83
Smile
frist chek volt on power key if no volt there then
Change keypaed IC , ur problem will solw .
Old 03-30-2011, 12:12   #11 (permalink)
Member: 664682
thnkx so mutch my prob. will solv
Old 07-12-2011, 13:00   #12 (permalink)
Member: 1359199
Sonork: 100.1602302
Thanks Meter: 23
Unhappy plz help m,e urgent
nokia 2690 phone perfect on flashing cable but not on for battery plz help me give me any solution
Old 06-10-2012, 07:33   #13 (permalink)
Member: 682764
Thanks Meter: 32
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 4], SN: C086AA08
Using device: HTI, FW ver: 00.50, SN: 000123AD
Connection status: UHCI:HUB:USB 2.00 (Full-speed)
Driver: WinUSB, ver: 3.5.1.0
Module ver: 1.0.0.20814(05-05-2012), Library ver: 1.0.0.14060(05-05-2012)
Preparing phone for SW downgrade ...
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.0]
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 0980010A84450156A8BFF63A3B5910DE471319CF
ASIC MODE ID: 00
ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: RAP3Gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00
Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
eBB5ProtocolType: OLD
Storage0: 00EC 2400 - 0000 8A31 [Samsung K5N2833ATB,512 Mbits] type: FLASH,NOR, asic:CMT
Storage content: 0000 0000 0000 0000 0000 0000 0000 0000
Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.50.0 revision: 0.0 size: 0x23010
Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
CMT PAPUBKEYS HASH: C6B9354E81AC464DED33FC7B90295086150F4539
TransmissionMode: DDR&TX2
Processing MCU file: rm635__10.65.mcusw
[BB5,BB5 ALGORITHM] size: 17.99 MB
Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000
Storing certificate [NPC, VARIANT, R&D, CCC, HWC] ...OK
Erase size: 21 MB
CMT FLASH,NOR area [00000000-000006BF]
CMT FLASH,NOR area [000006C0-0001FFFF]
CMT FLASH,NOR area [00040000-000BFFFF]
CMT FLASH,NOR area [000C0000-0013FFFF]
CMT FLASH,NOR area [00140000-0137FFFF]
CMT FLASH,NOR area [01380000-0151FFFF]
erased in 1 min 8.516 s
Prog.status for Asic CMT ...
NOR: OK
Flash programming ...
CMT NOLO block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT PASUBTOC block sent
CMT PAPUBKEYS: C6B9354E [RAP Certificate v1 246] sent
CMT UPDAPP block sent
CMT DSP0 block sent
CMT MCUSW block sent
NOR: OK
Programming completed in 1 min 10.703 s
Processing PPM file: rm635__10.65.ppm_mr
[BB5,BB5 ALGORITHM] size: 3.19 MB
Erase size: 8.62 MB
CMT FLASH,NOR area [01520000-01DBFFFF]
erased in 13.547 s
NOR: OK
NOR: OK
Programming completed in 12.890 s
Processing CNT file: rm635__10.65.image_mr_blue
[BB5,BB5 ALGORITHM] page size: 128 K size: 7.63 MB
Erase size: 34 MB
CMT FLASH,NOR area [01DC0000-0215FFFF]
CMT FLASH,NOR area [02160000-03FBFFFF]
erased in 35.078 s
NOR: OK
NOR: OK
Programming completed in 29.813 s
Total time for flashing process(boot+erase+write) was 3 min 58.406 s
but set not powering on
Old 01-03-2013, 18:08   #14 (permalink)
Member: 1642981
there is no voltages on on/off switch. help mr please.
Old 01-09-2013, 15:42   #15 (permalink)
Member: 1767975
Thanks Meter: 27
change both keypad ics
Page generated in 0.20828 seconds with 9 queries
