10-25-2012, 18:08 | #1 (permalink) |
Junior Member Join Date: Mar 2012
Member: 1738626 Status: Offline Thanks Meter: 2 | nokia 2700 |
The Following User Says Thank You to Isabab For This Useful Post: |
10-27-2012, 08:35 | #3 (permalink) | |
No Life Poster Join Date: Oct 2012 Location: india
Member: 1825795 Status: Offline Sonork: 100.1621021:98 Thanks Meter: 183 | try this Quote:
or change it ic easy available in maret | |
The Following User Says Thank You to deepak. For This Useful Post: |
10-27-2012, 09:17 | #4 (permalink) |
No Life Poster Join Date: Feb 2012 Location: kanpur
Member: 1722956 Status: Offline Sonork: mybestfriend.adeel Thanks Meter: 305 | you can use nokia 5130,2690,mmc ic for nokia2700c mmc. remove damage mmc and clean pcb. put new ok mmc ic and flow heat slowly. when mmc ic catched pcb put past on mmc and flow heat with good air. mmc ic will set its own place. if mmc not work after it then change mmc jack. |
