Old 02-05-2009, 21:01   #1 (permalink)
Member: 143538
E51 not work. Please HELP!
My E51 dead.
Phone does not start up. when pressing the power key. When pressing the power key notification light and display backlight wake up. Vibra makes on jog. Phone will take 230 - 250 mA current, but nothing else happens. After 30 seconds phone will power off.
Solution not work!!!
Procedure:
1) Flash E51_blank_504KB_pmm_10.fpsx file to phone with firmware update:
Firmware Update-> Options -> select E51_blank_504KB_pmm_10.fpsx into
Image field and empty other fields
2) Flash the whole SW package to phone with firmware update
3) Run factory settings
Phone should work now. Phone memory is empty and you can't save any old
data from phone memory. Memory card and SIM card should work as earlier.
I flash my phone V 100 and 200 and 300, not work.
UFS log press check:
1ST BOOT : C0,07 [Rm-244] [2.0.8.0]
RAPx ID : 000000010000022600010006400C192101021103
EM 1 ID : 00000295
EM 2 ID : 00000B22
RAPx PBID : 14600102796B0052B49E2E689A9025BE9CAFAEED
RAPx MODE : 00
RAPx HASH : CAEEBB65D3C48E6DC73B49DC5063A2EE
RAPx ROID : A8C1D6713E691FF8
CMT 1ST Boot OK
CMT 2ND Bt: RAPIDOv11_2nd.fg, Ver: 1.30.0
CMT FLID0 : 00EC0040-00600022, Sam OneNAND-2G
CMT FLCNT : 00030000000000000000000000000000000000
CMT MCID0 : FFFF0000-00000000
CMT 2ND Boot OK
CMT ALGO : RAPIDOv11_algo.fg, Ver: 1.35.0
CMT KSIG0 : 35AC54F8E31BE1357AB78D73834F020906331653
CMT VPP : Internal
DUAL LINE : True
CMT ALG Boot OK
INFO_2ND : APE Chip Absent
INFO_ALG : APE Chip Absent
Rebooting Mobile
UFS log press info:
MCU SW : V 200.71.814 09-04-08 RM-244 (c) Nokia
PPM SW : 200.34.36
Prd.Code: 0555751
Bpr.Code: 0545341
Prod.Sn : SAP364075
HW Vers : 0801
EM VILMA: 15
EM BETTY: 22
RFIC Ver: 17141715
DSP Vers: SI07w15PB_08w10
WLAN Id : 6FD30DDF1F
IMEI : 354193-02-777098-6
SL Serv : SIMLOCK SERVER
SL Conf : 244-07-00000000000
SL Stat : 0000000000000000
SL Count: 00 00
Provider: Nokia Test;Finland
Check, flash, info, local mode, test mode, self test - work!!!
Normal mode - Init Normal Mode Failed, Fatal Error
Please help...
Old 02-06-2009, 00:23   #2 (permalink)
Member: 599240
Helo Br nokia e50 ringer is low please help me
Old 03-23-2009, 11:06   #3 (permalink)
Member: 404729
pls let me yhe the following regarding E-51
1.set is showing charging but there is no reponse means ON.
2.ON/Switch ic location .
pls provide as soon as possible.
thanks
Old 02-11-2011, 16:48   #4 (permalink)
Member: 312822
Thanks Meter: 3
Agarkov_Igor:- this is hardware fault. First reball or change thavo ic if problem not solve than reball or change ritu ic. problem solve 100%
Nokia 6220 Data Cable not working. Please help... Muzzy Nokia Digital Core Technology 4 ( DCT-4 ) 1 07-22-2004 20:38
3300 KEYS"0" "4" not working please help me mohammed Nokia Hardware & Hardware Repair 0 05-10-2004 22:21
EMMI-2D Not work,,,PLEASE HELP! VsH-GsM Motorola Old Legacy (EMMI) 2 06-03-2003 23:46
C55 - JavaActivator not worked - please help me MrK E-Gold Based Phones 2 04-19-2003 23:32
Page generated in 0.17797 seconds with 9 queries
